603,947 active members*
2,391 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Can't get Y and A slave moving in the same direction
Results 1 to 5 of 5
    Jun 2013
    454
    Hey G'day people,
    I have nutted out what I need to with UCCNC except I can not get Y and A moving in the same direction.
    I know how to do it in Mach its real simple.
    Can I get it to happen in UCCNC nup..
    I have a CnC where Y axis needs two steppers.. so it has a slave A.
    Ive spent 2 hours looking and am probably overlooking because Im looking to hard if that makes sense.
    Cheers and thanks in advance.
    Steve
    Aug 2006
    143
    Re: Can't get Y and A slave moving in the same direction
    On the axis setup page for the drive going backwards check the active low boxes on step and direction (or uncheck) and that will reverse the direction.
    Jun 2013
    454
    Quote Originally Posted by derek View Post
    Derek hey G'day,
    Many thanks for the reply, of course right in front of my nose. But when your so used to do things in a different way sometimes the bleeding obvious is well just too obvious.
    Grateful for your post,
    Cheers,
    Steve
    Dec 2010
    634
    Don't feel too bad - I had the same problem when I switched over. They should really re-lable that checkbox or at least but (reverse axis) in parens in there.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Jun 2013
    454
    Quote Originally Posted by BanduraMaker View Post
    Hey g'day,
    Thank you for your post, I'm sure they will. I guess sometimes the coders/manufacturers assume that the person on the other end knows what it means. No their fault more mine for not being smart enough lol.
    Otherwise functioning as intended.
    Cheers,
    Steve
  1. Intermittent Slave axis direction reversal
    By MitchellT in forum Gecko Drives
    Last Post: 12-25-2013, 09:16 PM
  2. my cnc machine not moving in Z direction
    By durga prasad in forum Open Source CNC Machine Designs
    Last Post: 04-09-2013, 06:51 AM
  3. mach 3 slave motor(stepper) turns only one direction??
    By xkadet in forum Machines running Mach Software
    Last Post: 01-03-2013, 09:59 PM
  4. How to invert slave motor direction?
    By toolbox911 in forum Stepper Motors / Drives
    Last Post: 02-14-2006, 04:16 PM
