588,126 active members*
5,073 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Oct 2015
    18
    Can't load screens in mach3
    I recently purchased a new cnc router and it came with Mach3, so I installed it and everything works from main screen, but I am unable to load all the other screens (mdi, offsets, etc.). The other screens are in Millbitmaps, but when I try to load them, the only options are for files with .set ext. and bitmaps are .bmp. The main screen file is in 1024.set. Any ideas would be appreciated. Thanks
    Mar 2003
    35538
    Re: Can't load screens in mach3
    You just click the MDI or Offset buttons. They are not separate screens, just different pages.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2015
    18
    There is no mdi button or offset button, there are separate screenshots which are in Millbitmap, but can't be loaded because it has to be a .set ext. I inquired with Artsoft and gave them all the info, including license info, and the tech specialist told me it is a pirated version of Mach3, which may explain why it is not like the real thing. Guess I'll have to download the real thing. Thanks.
    Aug 2009
    610
    Yeah having genuine OEM software is probably a big help versus trying to run with an eye patch on. As would be fishing in the right forum for applicable advice and results. Thankfully Ger21 spans the boundaries here :-). Good luck!
    Mar 2003
    35538
    There is no row of buttons across the top of the screen?
    Typically, a pirated version is just a standard version with a pirate license.
    All versions of Mach3 have the different screen backgrounds in the \Millbitmaps\ folder, but all those are contained in the 1024.set screenset.
    It sounds like you just don't know how to use Mach3.
    Gerry
    Oct 2015
    18
    No buttons across top. The only thing across the top is "CNC 6040Z engraving machine control panel". I have uninstalled and reinstalled the software twice, with no luck. The only thing in the 1024.set is the main screen. I followed the instructions exactly. You're right, I have never used this software before. Thanks for your input.
    Mar 2003
    35538
    Then they supplied you with a custom screen.
    What you are seeing in the \MillBitmaps\ folder are not separate screens, but images from the stock Mach3 screenset.
    You need to download a standard version of Mach3 if you want to use those screens.
    Gerry
    Oct 2015
    18
    I agree, that's why I'm going to download from Artsoft. Thanks for your input, I really appreciate it!
    Oct 2015
    18
    A little off the topic, would you recommend Mach3 or Mach4, and why. I am an experienced machinist for the past 30 years. I have been a moldmaker, toolmaker, cnc programmer and machinist and a manual machinist, which I am still doing. I will be using a cnc router. I am using a laptop with windows 7 professional 32bit, which I am willing to upgrade for best performance. I will be using it for my own use, not production. I would appreciate any ideas or suggestions you might have. Thanks
    Mar 2003
    35538
    If you have no previous experience with Mach3, then my answer would be neither.
    I'd look at getting UCCNC and their UC100 motion controller.
    Mach3 can be problematic when using the parallel port on modern PC's. It's works fine for some, and not so well for others. Many end up getting a motion controller to work around this.
    The UC100 will work with both Mach3 and UCCNC, but UCCNC has a much better trajectory planner and gives smoother, faster motion. It's also actively being developed. Mach development stopped several years ago.
    Mach4, imo, is just not a finished product yet.
    Gerry
    Oct 2015
    18
    Thanks. I am using a laptop with usb to motion controller. Thanks, I appreciate your candor. Sorry to keep bothering you, but I would like to know your opinion on my OS. I am running Windows 7 professional 32bit. Does Mach3 work with 64bit, if so, would I be better off upgrading to 64bit with what I have, going to Windows 8 64bit, or staying with what I have? Thanks again
    Oct 2015
    18
    Mar 2003
    35538
    It really depends on what you're using the PC for.
    Are you just using it for Mach3? If so, then I'd say to just stay with what you have.
    I would only change to a 64 bit OS if you need to run 64 bit software on it.
    Mach3 will run on 64 bit software, but it can't use the parallel port. It will only work with a motion controller on a 64 bit OS.
    Gerry
    Oct 2015
    18
    The laptop is only used for Mach3, and I am using usb to motion controller. Thanks for all your help.
    Oct 2015
    18
    Downloaded Mach3 from Artsoft, installed, and I got message:Corrupt install, No license file found, Aborting. any ideas?
    Mar 2003
    35538
    completely uninstall all previous versions, and download again and re-install.
    You might want to try removing your pirated license file first. That may be causing it. Newer versions of Mach3 won't run on a pirated license file.
    Gerry
  17. #17
    Oct 2015
    18
    Got mach3 downloaded and things look good, but the motors don't work. Any of knowing if pin numbers are correct? Port setup is good, motor outputs X,Y,Z enabled, X-2,3 Y-4,5 Z-6,7(Step pin, Dir pin), Step port, Dir port- All 1's. Arrow keys change numbers in dro, but motors don't move. Checked motors and you can't move by hand. I am using ausb to motion controller connection. Could it be I downloaded the wrong software?
  18. #18
    Oct 2015
    18
    I think I figured out what I have to do. I think I have to also download the memoryoverride.zip also, since my OS is 32bit. Hope that's it.
  19. #19
    Mar 2003
    35538
    Did you install the plugin for the motion controller?
    Did the machine come with an .xml file?
    That should have nothing to do with it.
    Gerry
  20. #20
    Oct 2015
    18
    I went back and downloaded the old mach3 software(in a different file) and copied the Plugin, and integrated it in the new Mach3 file. That did the trick, I now have movement. I can't tell you how much I appreciate the help and advice you have given me. It was very generous of you to let me take up so much of your time. I have learned a lot from you. Thanks again!
Page 1 of 2 12
  1. Can't load all screens
    By keralesh in forum Tormach PathPilot™
    Last Post: 11-26-2015, 12:14 AM
  2. mach3 demo screens messed up
    By Mike Everman in forum Mach Lathe
    Last Post: 06-14-2008, 12:57 AM
  3. State of designing screens for Mach3?
    By ozzie34231 in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-10-2008, 10:14 PM
  4. New Mach3 screens.
    By ynneb in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-20-2007, 02:27 AM
  5. Mach Screens won't Load
    By TurboStew in forum Mach Mill
    Last Post: 10-17-2006, 03:54 AM
