588,442 active members*
5,983 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Cant seem to get forward and reverse signal from my KMB-1 to my relays for VFD
    Feb 2011
    53
    HI,
    SO I can't seem to get my KMB-1 to output the different signal to the relays that run my vfd.
    As it was hooked up when I bought it...
    Mill TB2 term 7 fwd
    TB2 Term 9 rev
    TB2 Term 8 ground signal from J4 term 14 from Z axis board
    TB2 7 & 9 go to ice cube relays that give me a dry contact to switch my VFD into fdw or rev mode.
    Is TB2 #7 only a momentary signal or should it stay on all the time?
    I would think that TB 2 7 & 9 should be switching the ground signal from J4 #14 so I can get + or - rpm from the spindle. so far no luck it just seems to always driver TB2 Term 7 (Fwd)
    THanks...
    God bless...
    Mark
    Feb 2011
    53
    Hi, so does anyone have a schematic/ description of what each of the relays on that relay board with all the "Ice cube" relays do?
    THanks
    God bless...
    Mark
    May 2011
    24
    Mark,
    I'm not sure how much it will help you, but, here is a link to what I did to make my KM-3 work with a VFD. It includes step by step instructions and schematics.
    http://home.windstream.net/rbalister...conversion.pdf
  1. Warning! Z axis forward!
    By Tom Curran in forum CamSoft Products
    Last Post: 04-02-2010, 12:15 PM
  2. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  3. Spindle Forward/Reverse = High/Low change
    By AdyAstley in forum Machines running Mach Software
    Last Post: 06-07-2007, 03:33 AM
  4. Forward Controls
    By raceshop in forum MetalWork Discussion
    Last Post: 01-05-2007, 05:48 PM
  5. Can bad forward/reverse toggle cause motor not to spin?
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 06-03-2006, 02:45 PM
