587,760 active members*
2,739 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Can't start spindle (servo based) at high speeds
    Mar 2008
    8
    I have a custom spindle that is servo based. If I start the spindle at 500 RPMs I can step it up to 1000 RPMs and have it run well. However, if I try to start it at 1000 RPMs it simply jerks. I have geck320 servo drivers being controlled by a true logic board.
    The machine was running nonstop from July 5th to last week when the problem suddenly arose.
    Mar 2008
    8
    Furthermore, if I detach the encoder there is no fault and the motor runs.
    Dec 2006
    839
    What do you have the fault count for the drive set to? I just cant amagin it not faulting when you unhook the encoder and some kinda hugh fault count is the only thing I can think of out side of driver going bad.
    DO you have another driver to try?
    Jess
    GOD Bless, and prayers for all.
  1. High Speed Servo Based CNC controller board
    By davidchow in forum Open Source CNC Machine Designs
    Last Post: 05-25-2010, 04:28 PM
  2. PC Based high-end CNC controller
    By CNCcontrol in forum News Announcements
    Last Post: 05-27-2009, 08:15 PM
  3. Feeds, Speeds and Depth of Cut for Nickle Based Material?
    By mgb1974 in forum MetalWork Discussion
    Last Post: 05-22-2009, 12:12 PM
  4. High voltage & high power servo drive design
    By Xerxes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-23-2008, 03:24 AM
