603,326 active members*
2,952 visitors online*
Results 1 to 4 of 4
    Nov 2004
    245
    Capacitor Bank Help
    Hi all,
    Can someone take the attached photo and photoshop it to show me how to connect the capacitors both in parallel and in series?
    I would surely appreciate it.
    Dec 2003
    24260
    If the terminals are not polarity marked then they can be connected without concern for the input supply polarity.
    For parallel operation one side of the supply is connected to the same terminal on each capacitor the other side of the supply to the opposite terminal.
    For series, one side of the supply would connect to one terminal of a capacitor, the other terminal would connect to the second capacitor etc.
    This show it diagrammatically.
    http://www.allaboutcircuits.com/vol_1/chpt_13/4.html
    They appear to be AC type motor caps.
    Al.
    Albert E.
    Nov 2004
    245
    Like this for parallel?
    Dec 2003
    24260
    Correct for parallel.
    Al.
    Albert E.
  1. multi drill bank/head
    By pinkjas in forum DIY CNC Router Table Machines
    Last Post: 04-07-2009, 08:04 AM
  2. 2008 Bridgeport EZ Vision Bank Repo
    By acme75kva in forum News Announcements
    Last Post: 03-09-2009, 06:29 PM
  3. scmi drill bank
    By wcmboss in forum Commercial CNC Wood Routers
    Last Post: 03-23-2007, 03:49 PM
  4. help with capacitor
    By charles wilson in forum CNC Machine Related Electronics
    Last Post: 02-13-2007, 07:12 PM
