587,997 active members*
1,882 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    May 2010
    capps programming
    i have enabled the canned cycle option under (caps system parameters) #9, but for some reason when i use the free form material style(4) the canned cycle option is not avaliable, but for the other 3 style of stock(1-3) the canned cycle option is avaliable, can you please help me out because all of the cast i machine is formed mateial.
    Can you also let me know if i could change the clearence values for the g76 threading canned cycle.
    thank you
  2. #22
    May 2022
    Quote Originally Posted by the thrill View Post
    if anyone has any CAPS questions, ask me. I'm something just shy of an expert
    I just got a feeler Cnc lathe and I am stumped on using the CAP programming function any chance I can get a walk through on the procedure. It would be much appreciated thanks Joe
  3. #23
    May 2022
    8
    Re: Caps programming.....
    please help me , i need post processor for citizen cincom m32 to machining in esprit pleas urgently
  4. #24
    Aug 2023
    Quote Originally Posted by Chuck Pressure View Post
    How many of you Mori users are using the Mapps/Caps programming to make your parts??? I find that I use it for almost everything lately! Sure saves time.....Anyone using it for turn-mill applications? I gotta belive its similer to mazatrol as far as speed goes, print to part......anyone use both for comparision?
    Do you know where I can purchase the software as a download??
  5. #25
    Quote Originally Posted by NL2000 View Post
    I work for a Mori dealer and I teach CAPS programming. It can do anything Mastercam, PartMaker, Esprit etc. can do. I haven't found any feature I couldn't program with it. Works great for turn/mill as well.
    How can I contact you? I’m looking for a software download for a SL 603. Lathe with MSX 500 3 controller. I’d like the Mapps programming software downloaded to a laptop if possible
Page 2 of 2 12
  1. SL-603 CAPS
    By kato in forum Mori Seiki lathes
    Last Post: 08-26-2011, 08:55 AM
  2. " L Caps" programming software
    By bush1355 in forum OpenSource Software
    Last Post: 04-24-2010, 10:32 PM
  3. Caps
    By fatboy55 in forum Charter Oak Automation Support Forum
    Last Post: 02-15-2010, 05:43 PM
  4. caps-m?
    By gravy in forum Mori Seiki Mills
    Last Post: 03-02-2008, 01:12 PM
  5. Have 3 caps, which one to use?
    By juxtoposed in forum CNC Machine Related Electronics
    Last Post: 04-21-2005, 06:43 PM
