587,082 active members*
2,796 visitors online*
Results 1 to 4 of 4
    Dec 2007
    379
    Carvesmart smart stops?
    Dumb question. What you are doing for the hole for the 1/4" smart stop dowel pins used on the carve smart jaws? Are you drilling and reaming for press fit or slip fit?
    Apr 2014
    185
    Re: Carvesmart smart stops?
    Quote Originally Posted by LazyMan View Post
    I just use a 6.20 mm drill bit and once the hole is done, I tap the dowel in with a Nylon mallet.
    Michael
    Nov 2007
    2151
    I need to pick up a pair of these. Forgot what a pita it is pull jaws off and replace with soft-jaws then change back. But I am stunned at the cost for the hardened Jaw set tho!
    About same price to buy another vise and use one for carve smart and other vise for hardened Steel jaws.
    Mar 2009
    1863
    I bought 2 Tormach CNC vises about a year and a half ago and immediately took the hardened steel jaws out and replaced them with aluminum soft jaws.
    Aluminum jaws are much easier on tools if you program a bad move.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
  1. Mounting Carvesmart jaws on 5" CNC vise?
    By sansbury in forum Tormach Personal CNC Mill
    Last Post: 01-12-2017, 07:53 PM
  2. CarveSmart jaws for Tormach 5" vise?
    By MichaelHenry in forum Tormach Personal CNC Mill
    Last Post: 07-29-2016, 04:27 AM
  3. Buy Smart Bar Puller,Get Bonus Smart Bar Stopper
    By ARIK in forum News Announcements
    Last Post: 03-01-2011, 04:10 AM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
  5. Smart cam ????????
    By shelburnebri in forum Uncategorised CAM Discussion
    Last Post: 12-07-2006, 08:27 AM
