Has anyone found something to clean a part after case hardening it? Something that will work quick.
A sand blaster, wallnut or plastic media?Originally Posted by larry53
If it was required to maintain the finish, cased in a vaccum furnace prevents most of the scale.
I'd be wary of acid etching.
DC
Thanks for the reply,however I am a small shop,I only want to clean up the part without using a brush if possible.
Ultimately you will need to decide on what finish you expect or can live with. Then go from there.Originally Posted by larry53
Wire wheels clean up scale nicely. Scotch brite pads do ok too.
The size and shape of the part may limit some choices.
DC
are you doing your own? place i send mine to always runs it through the sand blaster. whatever nasty stuff is in the solution they soak it in can hang around become stuck in holes, crevices etc. if they don't get this crap out, i've found it makes things rust like crazy.
It depends on what you're case hardening, but if you coat it with soap first it will have a tendancy not to scale. Works well with O2
