586,052 active members*
3,935 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Cast alloy z plates, steel & concrete frame, crazy composite gantry 4 x 8
    Hi all,
    This is something of a reboot project. I started it years ago and life got in the way.
    Here's what I have so far:
    A big steel frame, made from old I beams and 100mm box. The I beams are steel braced and half-filled with glass fibre reinforced concrete.
    2 reasonably levelled (epoxy) rails with shs30 guides (on the big I beams which act as sides) - the X axis has 2 ballscrews with rotating ballnuts.
    A freakish composite gantry (y-axis), made from old stairlift extrusion, steel bars and EG infill. It has epoxy levelled rails like the x, but with shs20 guides. It has a central 20mm pitch ground Hiwin ball screw. (most of this gantry was done long ago, and I actually posted about it in this thread: https://www.cnczone.com/forums/diy-c...derations.html
    The carrier plate for the z axis. I have just recently cast this in aluminium alloy. My games with that can be seen in this vid.
    https://youtu.be/Jh4MVzn61dg
    I don't see many diy folks melting and casting aluminium for their CNC projects, so I thought that may be of interest.
    I have 400w AC servos & drives that I think I am close to getting grips with - I have them moving anyway.
    I made some big blunders with the 2 x ballscrew - which are detailed in these 3 short vids here:
    https://youtu.be/HF-OtLCGphg?list=PL...bvZxeouH5TyNrZ
    Whats left:
    The remains of the z axis: the motor mount, the spindle career box/maybe casting
    Mounting, aligning and tweaking the new 20mm pitch x ballscrews. To do this I need to make re-work some new HTD pulleys to fit the rotating nut design and do a few other bits on the lathe.
    The enclosure for the electronics
    Learning how to use it! tests, etc etc.
    The purpose of this post is to: a, share some of this madness with the potentially interested,
    and b, get some feedback on the steps going forward. What obvious tasks am I missing? Do you have any feedback/thoughts for the spindle carrier plate/box, that will make things easier (problems described at the end of the first video)?
    Ok that's enough for one post. Thanks for reading guys
    Bongodrummer - www.FloweringElbow.org
    Jan 2005
    15362
    Re: Cast alloy z plates, steel & concrete frame, crazy composite gantry 4 x 8
    Quote Originally Posted by Bongodrummer View Post
    Hi all,
    Whats left:
    Good to see more progress
    Mactec54
    Hey Mactec, thanks It's obviously not as continuous as I would like, but there it is. Gotta try and keep the ball rolling now :cheers:
  1. Building Steel Frame Gantry Router for wood, MDF, and maybe more
    By thegadgetguy in forum DIY CNC Router Table Machines
    Last Post: 10-01-2023, 09:56 AM
  2. Composite Steel Gantry Mill - Seeking Feedback
    By PaulAmelang in forum CNC "do-it-yourself"
    Last Post: 05-22-2021, 07:47 PM
  3. A Fixed Gantry Cast Iron/Steel Build
    By yezard in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2018, 10:00 PM
  4. steel frame gantry flex
    By wentyfalls in forum CNC Wood Router Project Log
    Last Post: 07-04-2013, 05:37 PM
  5. Moving Table Steel & Concrete Rebuild
    By JohnZ in forum CNC Wood Router Project Log
    Last Post: 07-04-2012, 09:55 PM
