I want to experiment a bit with building my own woodworking machines. The hardest part by far, IMO, is fabricating the tops, frankly because I can't make my own castings and I don't have a giant surface grinder.
Does anyone here know of a source of various sized cast iron tables? If I can't find what I need in cast iron, is thick sheet steel a viable alternative?
As for grinding the tops, is there a way to accurately grind a part that's bigger than the capacity of a surface grinder? The part would need to be repositioned halfway through the grinding process. Will the repositioning throw the whole thing off? Accuracy needs to be about 0.003".
Thanks.
