Not sure if this is the right place to post this but.
Just wondering what kind of circuit is used to op/close cd trays on desktops. You push the button it opens and stops the motor at the end and then you push the same button and it closes and stops the motor at the limit. You can also switch direction pushing the same button again in the middle. Or even more complicated one of those car flip up screens where they come out stop, flip up stop move in a bit and stop. Then you can do the same thing in reverse.
Thanks.
