603,936 active members*
2,247 visitors online*
IndustryArena Forum > CAM Software > Mastercam > chaining arrow not visible
Results 1 to 5 of 5
    Feb 2009
    mastercamx3 ive loaded it on my dell laptop windows vista when i go to make my toolpaths my chaining arrow is not visible on the screen cant find setting please help
    Mar 2005
    461
    What type of graphics card does that laptop have ?
    A couple things that could help would be found in Settings, Configuration... Under the Screen tab...
    Try checking the disable hardware acceleration and/or the disable front buffer checkboxes...
    If that doesn't help then at least if you let us know what the graphics card is somebody else can give more ideas...
    Aug 2008
    64
    Did you also load MU1?
    Jul 2006
    297
    sometimes i cant see the arrow when chaining solids i click the wireframe tab and all is ok.
    if you are not chaining a solid then i would listen to the posts above.
    2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
    Feb 2009
    Smile windows vista chaining problem
    thank u the hardware deceleration worked thanks again
    im new to this forum and its great!!!!
  1. retired toolmaker/cnc programmer
    By weeli in forum Stepper Motors / Drives
    Last Post: 11-26-2009, 05:12 AM
  2. Pro/Toolmaker, has anyone tried it?
    By Adam Hubert in forum PTC Pro/Manufacture
    Last Post: 10-31-2008, 08:09 AM
  3. Child of machinist/toolmaker
    By beartrax in forum Polls
    Last Post: 10-01-2008, 08:11 PM
