588,136 active members*
6,286 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Chaining from specific start point for plunge
    Sep 2004
    22
    Hey guys I guess I thought I had a handle on this by now especially in the 2d area but Ive got a question that I need some help on . How can I start a cut from a start hole or specific starting point so the cutter will plunge there instead of in the material. I dont know what Im doing wrong I can get the cutter to start at the retract position at the start hole but then it moves to the contour edge and then plunges then every pass it plunges without going back to the start hole. I know there is somthing I am missing that would just make it so darn simple but I just cant get it I know I have done this before with no problem but I just am stumped. I looked in our tutorial books and I cant seem to find anything that will help me in there either. I know it probably has something to do with the way I am chaining the contour first I chain the contour (which is a 2x3square that I want to cut out) and then I go and change the start point and click on the center of my start hole. Now it will start the cutter the first pass which even then its like I said before it waits to plunge at the contour wall.Anyway I know there is an easy way to do this If any of you could enlighten me on it I would be very thankfull.
    oh and this would pertain to version 9.1
    Aug 2007
    95
    Create a point where you want to start, then chain your pocket by clicking the point first,then your pocket.Then in you lead in/out options put value of zero in everything,then check the use entry point box.
    Sep 2004
    22
    SWEEEEEEET
    It took me forever to figure it out on my own but I finally got it I knew it was going to be so simple and it was thanks for your reply that is exactly what I did and it finally WORKED! Ive been at it for like 2 hours trying to get it to work now I can go make chips .
    Thanks for your reply
  1. Picking points without chaining
    By TeeGate in forum Mastercam
    Last Post: 03-22-2008, 10:46 PM
  2. Are there specific router bits for specific materials?
    By fivefishcnc in forum Uncategorised MetalWorking Machines
    Last Post: 02-24-2008, 02:35 PM
  3. How To Use Change At Point With Solid Chaining
    By Mastercam User in forum Mastercam
    Last Post: 12-10-2007, 04:56 AM
  4. Where to start ? point me in the right direction...
    By cruizer67 in forum DIY CNC Router Table Machines
    Last Post: 09-13-2005, 02:44 AM
  5. 2D Toolpath Start Point?
    By mlinder in forum OneCNC
    Last Post: 09-07-2003, 05:28 PM
