603,394 active members*
3,270 visitors online*
Thread: Chamfer Help
    Jan 2013
    Chamfer Help
    Hello everyone!..
    I'm fairly new to the machining world, and I'm looking for someone help.
    I need to mill a 45 degree 15 MM chamfer on this part. The tool I'm using is a 45 degree index-able endmill. The inserts are about .300 from the center of the tool.
    How do I program the machine, using Acu-rite control and readout system. Do I just program a straight line 15 MM into the part?? Also I need to give the diameter of the tool. Do I then tell the machine its the smallest diameter of the tool (bottom of the inserts) or the largest diameter (top outer tips of the inserts)
    Any help would be much appreciate any help!!
    Mar 2006
    2712
    You could program the tip of the tool near the edge you want to chamfer then control the width of the chamfer with the depth of the cut. The deeper the depth, the wider the chamfer. Worked for me in the "old days)lol
    Dick Z
    DZASTR
    Apr 2006
    3206
    Put a test part in the machine, tip off the length of the tool from the top of the part so you know where the tip is relative to the Z0. Then put the center of the tool over the edge of the part. Now, step over away from the part a given distance of your choosing and step the spindle down till you get the desired chamfer.
    The distance away and your distance below the surface is your effective radius offset for a G41, and your depth down will be your Z- value. You can now use this set of values for future programming.
  1. 3D Chamfer
    By L98FIERO in forum BobCad-Cam
    Last Post: 12-09-2012, 10:04 PM
  2. tapped hole chamfer with iscar chamfer tools
    By dcutler35 in forum Mastercam
    Last Post: 12-07-2012, 02:30 PM
  3. Chamfer chamfer mill or ball mill
    By fjbart70 in forum Mastercam
    Last Post: 03-11-2011, 06:27 PM
  4. help with 3d chamfer
    By Justin Cavender in forum Mastercam
    Last Post: 01-23-2011, 10:56 PM
  5. 2D chamfer
    By jcnewbie in forum Mastercam
    Last Post: 10-19-2009, 05:06 AM
