603,970 active members*
3,078 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach Slant Lathe > Chamfering the edge or the part that is being parted off
Results 1 to 10 of 10
    Sep 2008
    325
    I have a part I am machining that I want a chamfer on the edge of the part that I will be parting off because I won't be facing it afterward. I tried using the conversational chamfer but it only seems to work for a feature on the right edge. Am I doing something wrong or is it not possible? How about adding a fillet to the right inside edge of a groove?
    May 2015
    111
    Re: Chamfering the edge or the part that is being parted off
    You cannot chamfer on the backside of the part - towards headstock - in the conversational PP. I had to do the same thing making some parts and finally did it in fusion to chamfer it and then part. It will leave a little nub on the part.
    Sep 2008
    325
    Quote Originally Posted by cbyrd View Post
    I wonder if there is a good reason for it or if it's just an oversight?
    May 2015
    111
    I am not sure, I did not ask Tormach about it. I assume it is because you are cutting into the full diameter of the stock.
    That is just my guess,.
    Jun 2004
    6618
    You should be able to do it if you groove it first. Partway to the part. Then it should allow that cut. Then part off.
    I haven't actually tried it though.
    Lee
    Dec 2003
    673
    Quote Originally Posted by LeeWay View Post
    Thats what I do... cut in a bit, pull out, chamfer, and and the bottom of the chamfer resume cutoff... its easy to just manually code that - I hand edit it into any machine generated code.
    Sep 2008
    325
    Quote Originally Posted by Spinnetti View Post
    Thanks guys for the replies. I ultimately ended up hand coding it but thought that the chamfer conversational should work in both directions. I did a shallow parting cut first, cut the chamfer and then finished the parting cut.
    I vaguely remember seeing something about chamfering in the grooving conversational but am not in front of the machine to be able to check it out.
    Sep 2008
    325
    Quote Originally Posted by saabaero View Post
    I just read this in the Chamfer/Fillet conversational section of the lathe manual.
    "Depending on the sense of the X and Z DRO entries, the chamfer or radius feature may face away from or toward the spindle, or use back or front mounted tooling."
    Jun 2004
    6618
    Sounds like it should work, but I have run into trouble with the conversational not letting you do something if it feels you are trying to use the wrong tool type. For instance, it will not let you turn a profile with a parting tool even though that type tools allows it sometimes. I do turn with my parting tool, but had to hand code that stuff.
    Lee
    Jun 2006
    3063
    I believe that the SprutCAM parting and/or grooving operations have an option for chamfering the edge on the headstock side.
  1. Replies: 9
    Last Post: 05-27-2014, 12:23 AM
  2. A little fuzzy on edge chamfering...
    By Spinnetti in forum Tormach Personal CNC Mill
    Last Post: 05-28-2013, 09:05 PM
  3. Chamfering Help Please!!
    By Randy727 in forum Solidworks
    Last Post: 07-22-2010, 11:27 PM
  4. Need help in chamfering
    By abcdef in forum MetalWork Discussion
    Last Post: 04-25-2007, 12:34 AM
