603,344 active members*
3,328 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Change between G71 type I and type II on leadwell LTC-10S.
Results 1 to 4 of 4
    Dec 2008
    446
    Red face Change between G71 type I and type II on leadwell LTC-10S.
    Hello. I have fount out that i can`t change between the Type I and Type II
    Can i do that if i change some parameters?
    I dont know anything about this things...
    Greetings from Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Sep 2010
    1230
    Quote Originally Posted by Vegabond View Post
    Hi Robert,
    No, its optional control software. Often the option is loaded, but requires an Option Parameter to be turned on, available from Fanuc at a cost. Sometimes the software does not exist in the control, but can be supplied by Fanuc.
    Regards,
    Bill
    Dec 2008
    446
    Ok..
    And the price is??? :P
    Sep 2010
    1230
    Ok..
    Robert,
    I'm not sure of the G71 cycle upgrade price, as I've never been involved with having this upgrade installed. The greater majority of machines past when Type II G71 cycles was first introduced in the Series 6TB control, have Type II already loaded and activated. However, I recently ordered Cylindrical Interpolation for a client's 0i controlled machining center at a cost of approx AUD2,100.00. A call to your local Fanuc representative will get you the information you seek.
    Regards,
    Bill
  1. how to change tool offset memory type on meldas 500?
    By Francois_DCM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-28-2017, 11:33 PM
  2. Lead Screw type and bering type????
    By cjluke in forum DIY CNC Router Table Machines
    Last Post: 07-20-2011, 04:42 PM
  3. G71/G72 type I vs. type II cycles
    By sinha_nsit in forum Fanuc
    Last Post: 08-28-2010, 11:20 AM
  4. G71 type I and type II cycles
    Last Post: 11-03-2008, 12:34 PM
  5. Leadwell MCV-OP do not change Tools
    By uli kolb in forum Uncategorised MetalWorking Machines
    Last Post: 08-14-2008, 04:00 PM
