603,939 active members*
1,943 visitors online*
Results 1 to 7 of 7
    Aug 2009
    16
    Wink change language of fanuc 6m
    Hi All,
    I want to change language in fanuc 6m (German to English), help me please!
    Thanks and Regards
    Apr 2009
    1401
    as far as I know, you will have to get new software. What version are you using now?
    Sep 2007
    371
    Yes, you'll need a new software. Call fanuc and see if they have the version for your machine in english.
    Good luck.
    Aug 2009
    16
    Hi workmates,
    I don't know exactly you told which version of machine, but i have maycenter machine (fanuc system 6m-model B) 1980s.
    Apr 2009
    1401
    turn control off.put control in e-stop.turn control on. the software will now show e.g. M51 Version12
    Aug 2009
    16
    Hi memoryman,
    I don't understand good,If possible a more detailed explanation.
    thank you.
    Apr 2009
    1401
    the software version shows on the screen right after power is on. Because the crt takes seconds to warm up, you may not see it. That's why you enable E-stop, so the version stays displayed. It may also be printed on the eproms on the ROM board
  1. Mo Language change
    By greenery_fr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-18-2016, 01:53 PM
  2. Change language of 21i-m
    By fomaz in forum Fanuc
    Last Post: 10-03-2009, 07:14 AM
  3. language change on meldas 310
    By zvizdic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-30-2009, 02:28 PM
  4. Language change on Mazatrol Cam T2
    By andreypav in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-14-2008, 03:23 AM
