Can't seem to find parameter to change the A axis home position. Need to change it to facilitate loading and unloading a fixture upon cycle completion.
parameter 224 rot axis zero offset doesn't seem to do anything.
There's no need to change the home position:
(END OF PROGRAM)
G0 G54 Aa.aaa
M30
Or what I do:
(END OF PROGRAM)
G0 G53 Z0.
G53 X-15. Y0. Aa.aaa
M30
Using G53 you can handle jog the A axis to where you want to park it at the end of a cycle, go to the position screen and simply use the value you see in the A axis readout.
Kinda like matt is saying you can use a fixture offset for the A axis at the end of your part program.
Lets say you run G55 on your part program.
at the end
have a G00 G90 G56 A0.0
just jog your A axis to were it needs to be when loading and set your g56 fixture offset.
Delw
