In a Fanuc 21iT with a hydraulic turret I would like to change the position for each tool. This is, currently when I command slot 1, the machine is going for slot 1, then commanding slot 2 the machine goes lets say in CW direction.
I would like to change the slot 2 position to another location (so that the turret rotates in CCW), but in a way what the machine would understand the new position as the correct one.
Slot 1 is the master and it is correct.
The reason is that I changed the turret disc and the new disc have the numbering in the reverse order, and in this way when I ask for slot 3, in the mark that is present on the disc it ends on slot 9.
Or maybe it would be better to mill the disc numbers ....
