603,818 active members*
4,028 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Change from yaskawa servo to delta servo
    Oct 2012
    Question Change from yaskawa servo to delta servo
    I have an servo pack of Yaskawa Servo Drive model no SGDH-10ADG with connected motor SGDM-08U3B4L my drive has been faulted and i want to change this inverter with any other make MITSUBISHI/DELTA while using the same yaskawa motor.
    Is this possible.
    Jan 2008
    106
    Quote Originally Posted by sachin.kumar View Post
    Is this possible.
    Where in India are you from ?
    The best answer to your question can come if you take the motor to the Delta outlet near you and ask their engineer the possibility of inter using Yaskawa motor with Delta drive.
    I personally think the outcome might be negative since its encoder and other properties might not match with the Delta drive.
    What did the Yaskawa engineer say to you about repair or anything else?
  1. Panasonic servo Vs Yaskawa servo
    By saratbabu in forum Servo Motors / Drives
    Last Post: 05-03-2013, 12:56 AM
  2. Yaskawa servo
    By toolwrite in forum Community Club House
    Last Post: 09-17-2009, 01:51 AM
  3. yaskawa servo drive
    By traxxtito in forum Servo Motors / Drives
    Last Post: 05-31-2009, 12:10 AM
  4. Yaskawa servo
    By rai in forum Servo Motors / Drives
    Last Post: 04-28-2009, 04:32 AM
  5. Yaskawa AC Servo
    By HillBilly in forum Servo Motors / Drives
    Last Post: 10-14-2005, 02:21 AM
