603,965 active members*
3,510 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Changes to Dimension Preference
    Jan 2004
    668
    I got the student version to go along with the classes I'm taking at a Comm. College. Well, after installing it I noticed it is set to mm, not inches. I'd like to set the default to inches. Anybody know how, and can send me details to do it.
    Aug 2005
    1622
    Open the original template for a solid part.
    Go to Tools>Options> Document Properties tab, Then change the template to what you want the defaults set to.
    Then go to "Save As" and save it as a file named "My Template" or "Inch". Using "save as type" set to Part Template=*.prtdot
    Make sure the location you are saving it in is pointed at the; Program Files>SolidWorks>Data>Templates folder so that when you open a new file from the wizard, your inch template is shown to select from.
    Things like this are in the help files also.
    DC
    Jan 2004
    668
    Thanks One of Many That is just what I needed to know. I did use help just didn't know what to ask it.lol
  1. G & M Code on a Gerber Dimension 200
    By quaturbo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-16-2012, 01:15 AM
  2. Gerber Dimension 200
    By teemac in forum Gerber
    Last Post: 04-22-2007, 05:30 AM
  3. Tapping Head Preference?
    By Otokoyama in forum MetalWork Discussion
    Last Post: 01-05-2007, 02:14 AM
  4. Changing object dimension
    By JRoque in forum Rhino 3D
    Last Post: 05-25-2006, 02:52 PM
  5. Cutter dimension dilema
    By Moondog in forum Mach Software (ArtSoft software)
    Last Post: 04-28-2006, 02:12 PM
