587,735 active members*
3,491 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Changing Home Position in Parameters on Fanuc Series oi-Model D (SMTCL)
    Nov 2008
    3
    Hi All,
    I was wondering if anyone knows the parameter # associated with changing the Machine X,Y home positioning? The machine is a SMTCL 850B, Fanuc Series oi mate -Model D.
    Thank you in advance,
    D
    Dec 2009
    972
    Re: Changing Home Position in Parameters on Fanuc Series oi-Model D (SMTCL)
    1815.4---APZ
    Like zavateandu wrote: 1815.4---APZ Move your axis to the location where you want the new home position to be then make it a 0 (You will get an alarm to power off, don't power off yet) then change it back to a 1. Now cycle power. Be careful in doing this as it will change the axis position and you might not be able to change tools any more if you changed that location by doing this process.
  1. Replies: 18
    Last Post: 04-11-2019, 06:09 PM
  2. Replies: 2
    Last Post: 04-20-2015, 04:47 PM
  3. Replies: 24
    Last Post: 08-21-2012, 02:08 AM
  4. home position for fanuc 0i mate model C
    By beth_piyik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-23-2011, 10:03 AM
  5. Changing home position
    By positiverake in forum Fanuc
    Last Post: 12-29-2009, 09:06 PM
