603,855 active members*
4,090 visitors online*
Results 1 to 12 of 12
    Aug 2011
    41
    Lightbulb Changing labels into RDworks
    Hi, I Martin from Argentina.
    I have a goldenlaser with two fixed heads, and software is really bad. And without support (chinesse and either local)
    Then i purchased a RDC6442s in china, right now i am waiting.
    Of course, i installed RDwork V8, and start to play... but apart of ugly operation manual, some labels into the software are at least, confusing...
    Then, I open the directory of RDworks and found some .txt like : lang_eng.txt and lang_other.txt
    Close rdworks,
    Simple open lang_other.txt with notepad, looking for .... "if blowing", found it, and changed it for ... "Air assist"
    Repeat
    go to "1" and so on...
    Then, open wdworks, and change languaje to "Other"
    Why Other and no Eng ?
    with you "new" languaje you are out of manual operator, or talk to other users, because you dont have anymore the "old" labels...
    solution : dont change lang_eng.txt, just change other_lang.txt then, if you need to find some "old" label, change to english, once found, you can change to "other" and operate normally
    Other cuestion, if you change a label and the number of characters is too much diferent (more), posibly the text appear over other items... be carefully
    And finally, in a upgrades of software i dont know what will be the result... maybe try and start again...
    Examples for me :
    if blowing = Air assist
    Sew compensation = Kerf compensation
    if light = Laser On
    Attachment 318328
    Martin.-
    May 2016
    30
    Re: Changing labels into RDworks
    Quote Originally Posted by otromar View Post
    Close rdworks,
    Repeat
    Examples for me :
    if light = Laser On
    Martin.-
    Great Martin thanks.
    Yes not much help to get from the Chinese
    Aug 2011
    41
    I realizad after post that there is not the right place for this post. Sorry. Please, administrators, can you move the post ?. Thanks
    Martín
    There is a new subversion (8.01.18) of RdWorks. At a first view, just a changes to allow control of 4 laser tubes...
    Jun 2014
    611
    blowing=air assist, just ignore it. It doesn't change anything.
    May 2016
    30
    I guess that depend on how the Air-assist is Connected?
    Jun 2014
    611
    Yes, but most of chinese machines doesn't make this option available.
    May 2016
    30
    Ok, but how easy would it be to do?
    Jun 2014
    611
    install an air valve, buy a high air compressor and change setting on the software.
    Aug 2011
    41
    Quote Originally Posted by Nolan Yang View Post
    Hi Nolan, the air assist if not conected to anything ? Can you tell me what controller are you using with RDwWorks ?
    Martín.-
    Aug 2011
    41
    Quote Originally Posted by Klausm2 View Post
    Hi Klaus, Ruida have you own site with all the manuals http://en.rd-acs.com/down_complex.aspx?FId=n14:14:14
    Some manual have really UGLY english version, but al least some circuit connections are legibleClick image for larger version.
Name:	air assist.jpg
    Jun 2014
    611
    RDC6442G, no signal connect to air assist, so even though you change the setting on software, the air assist still keep working.
    Aug 2011
    41
    Ok Nolan, seems that you have a lot of knowledge about ruida controllers. Can you help me with this ? http://www.cnczone.com/forums/laser-...r-2-error.html
    Thanks in advance
    Martín.-
  1. Multiple Electrical Labels
    By Waz in forum Uncategorised CAD Discussion
    Last Post: 05-11-2015, 03:05 AM
  2. Using labels in Edgecam
    By nigel2000 in forum EdgeCam
    Last Post: 03-26-2013, 10:32 PM
  3. Enroute Barcodes and Labels
    By Dave_Fusion in forum EnRoute
    Last Post: 03-05-2012, 05:57 PM
  4. Tool Labels - A powerful simple solution.
    By CholPeter in forum News Announcements
    Last Post: 12-14-2009, 10:58 PM
  5. Labels and stencil cutting laser, can you help, please?
    By MR T999 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-04-2008, 01:16 PM
