Introduction to charcoal briquette machine
Charcoal briquette machine is mainly used to press various powder and scrap materials such as charcoal dust, the bamboo carbon powder, breeze, hookah carbon, graphite powder, page shell carbon, common jujube carbon, LAN charcoal powder, activated carbon and so on. Charcoal briquetting machine can produce a lot special shape like square type, ball type, elliptic type, round type, column, bar, bread and pillow type. Charcoal briquettes making machine is widely used in refractory, power plant, metallurgy, chemical industry, energy, transportation, heating, animal husbandry, industrial, agricultural, barbecue and other fields. Charcoal briquette press machine is suitable for single machine operation and large-scale production line. Meanwhile, charcoal briquette machine is also suitable for mobile operation.
Technical principle of charcoal briquetting machine
Charcoal briquette machine has the obvious advantages of high rate into a ball, low power consumption, compact structure and convenient maintenance and debugging, thus charcoal briquetting machine or charcoal briquette press machine is no doubt rather ideal key equipment for Pidgeon's magnesium reduction process. This series of charcoal briquettes making machines pass on its power through the reduction boxer to the two compression rollers at the same time, making them rotate in opposite directions. During the rotation of the two rollers, the materials will enter into the ball mold on the compression roller. Along with rotating of the rollers of charcoal briquette press machine, the pressure that the materials endured will grow from small to big, and it reaches peak when the materials rotate to the contact points of the line of the two rollers. Under the great linear pressure, the materials will turn into the finished ball from the charcoal briquette machine in the end.
Advantages and benefits of charcoal briquette machine
1. This series of charcoal briquette machine has a reasonable design and a reliable manufacturing quality. It also has the advantages of simple structure, convenient operation, small volume, less occupation of the land, labor saving and power saving.
2. Because of the design of automatic control of electric heating device, users can adjust the dry materials randomly so as to ensure the materials are discharged stably. Eventually improve the work efficiency of charcoal briquettes making machine.
3. The main part of charcoal briquette machine adopts wear-resisting materials which through special processing, so it can be used to pressing production continuously and durable.
4. Charcoal briquetting machine has upgraded the three bearing movement of old type into four thus increase the stability and durability of the machine.
http://www.coal-briquettemachine.com...e-machine.html
