603,916 active members*
2,176 visitors online*
Results 1 to 10 of 10
    Feb 2015
    Charmilles Form 20 - Err GAP
    I have a problem with Charmilles EDM Form 20.
    After pressing START, CC starts flashing rapidly, LED bar itself goes up, and after a few seconds pops "Err GAP"
    I checked all the connections, plates, wires. Everything looks OK. Before this a couple of times jumped 6A fuse in the housing of the generator.
    The second thing, I do not have any documentation from the machine. I have only the Danish language instruction provider.
    Can someone tell where to start to look. Somewhere I heard that often damage the power supply. Where to look?
    Apr 2014
    11
    Re: Charmilles Form 20 - Err GAP
    Hi I just scored a Form 20.I haven't been able to run it,as I'm only a wire guy.I have lots of printed material,that I would copy and trade for tech on how to run this machine.Thanks,Doug 5417528628
    Apr 2014
    11
    Hi There!I have the operator's manual.Send me your address,and I'll send it to you,in cd form.I need help,as well.I am a newbie on this,and am looking for help on power setting,etc.Thanks
    Jan 2013
    25
    What kind of material are you burning? What kind of flushing? Lateral, through the part? Through the workhead? Do you need to pulsate aka "peck?"
    Jan 2015
    Bonjour
    J'ai une roboform 20
    Elle fonctionne bien avec le régime E403 mais quand je change le régime et je lance l'usinage l'axe Z prend le 0 puis il remonte dans le sens contraire.
    Aider moi pour résoudre le problème
    Merci
    Apr 2016
    I am just beginning to work with the form 20 I am trying to burn HSS with copper. I don't really understand how to change or know if I am using the right technlogy, I do know that in the program L:, is the depth I want to cut and the progtram I am using has H.0 and E:, 281.. with lateral flushing.. I ran it yesterday for a couple of hours and didn't even mark the surface. my electrode id only .069 dia. and going .032 deep. any help would be greatly appreciated
    Nov 2024
    4
    Tenemos un from 20 que no enciende nada.
    Puedes enviar información o un vídeo sobre que enciendo al subir el interruptor principal, yo que es un modelo escaso.
    Nos ayudaría mucho un vídeo sobre el gabinete de control trasero al energizar el control o subir el interruptor principal y ver qué fuente enciende para posterior mente encender.
    La nuestra no enciende nada del tablero de control trasero tenemos el voltaje de alimentación correcto de 440v pero no hay fuente encendida para llevar acabo el encendido los contadores de 24v.
    Nov 2024
    4
    Dejo mi contacto para cualquier información que nos puedan compartir, estoy tratando de agregar una foto de mi máquina pero no sé dónde adjuntarla.
    Este es mi correo ?? caasic.28@gmail.com
  1. charmilles edm
    By timf in forum Uncategorised CAM Discussion
    Last Post: 11-23-2021, 07:10 PM
  2. charmilles d 10
    By heartlnd in forum EDM Discussion General Topics
    Last Post: 05-10-2013, 02:09 AM
  3. What CAM for Charmilles?
    By LeMon Racer in forum EDM Discussion General Topics
    Last Post: 09-04-2012, 06:20 AM
  4. charmilles roboform 550
    By miller04 in forum EDM Discussion General Topics
    Last Post: 10-29-2010, 06:31 PM
