587,771 active members*
3,031 visitors online*
Results 1 to 10 of 10
    Jun 2006
    35
    Charmilles Robofil 200 programs
    Does anyone have some sample programs for a Charmilles Robofil 200? I am still waiting on my manuals from Charmilles. I get 2 files when I post from my CAM software. The first one is myprogram.cmd and the second one is myprogram.iso. The .iso file seems to be standard gcode but the first is a little strange to me. Any help would be greatly appreciated.
    Feb 2009
    48
    Does your programme have multiple contours. The .cmd programme is often used to call sub programmes.
    For example your .cmd programme might have all your start point coordinates and then call your programme after each move has been made
    Sep 2006
    18
    .cmd programs
    Yes this appears to be the way it works on my machine.
    Do you have a sample like this that I can look at?
    I have a multiple fixture/part setup to do, right now I run one .iso program and then the other one.
    Feb 2009
    48
    That machine is a little older than I realised so not exactly sure on the control.
    You could try something like this.
    G0 X0 Y0
    S101 (Service pack technology for rough)
    M98 P1008 (Sub programme call)
    G0 X0 Y0 (Linear rapid)
    S102 (Technology setting for finish pass)
    G77 P2 (Positioning at stored measured point)
    S201
    M98 P1009
    etc......
    Jun 2006
    35
    Very good
    Thanks, much appreciated.
    Dec 2011
    Smile robofil 400 E694 FAILED
    hello,good everybody .
    Started *.ISO PROGRAM ,displayed E694 rear cover open,in my ROBOFIL 400.How any body know whats meanes.
    Jun 2006
    35
    Switch on rear of machine at the wire exit to the catch basket is not tripped or possibly the wire has gotten out of the basket and shorted on the machine somewhere. Don't forget to press other button (not wire feed button) above the wire supply roll to reset the rear cover open condition.
    Dec 2011
    Smile
    HI:
    Thank you for your helop,the E694 was solved. but I don't know in the:SET UP-PARAMETERS,the ZDES、 HPA means?can you help?
    Dec 2011
    HPA is workpiece thickness
    ZDES is Z draw...height above center of lower nozzle at which you want to draw
    the contour..
    Dec 2011
    Smile THANK YOU very much
    Thank you for your help.now I need post of MASTERCAM 9.1 SP2 for ROBOFIL 400.and needs 852478 ccu exe CMOS chip program:978081,978553(?) for ROBOFIL 100.can you help me?my email :[email protected]
    and what'S means about :TEC table:C,P,Fn ,F,Sr,AJr,WSr,OFr.OF,HEDIT.and WIR table:OP,TE,TW,P,R,VE. C.AJ?
  1. CHARMILLES ROBOFIL ALARM/MANUAL
    By SINUMERIKO in forum Waterjet General Topics
    Last Post: 10-13-2023, 08:18 AM
  2. Charmilles Robofil 200 startup
    By Shawn Lucas in forum EDM Discussion General Topics
    Last Post: 07-23-2021, 12:20 PM
  3. Charmilles Robofil Wire Edm
    By sundara in forum EDM Discussion General Topics
    Last Post: 08-01-2017, 09:56 PM
  4. Charmilles Robofil 440 Power Settings?
    By Tool Maker 24 in forum EDM Discussion General Topics
    Last Post: 09-10-2009, 10:50 AM
  5. Charmilles Robofil 300/310 Door Alarm
    By WIRE CUTTER in forum EDM Discussion General Topics
    Last Post: 07-26-2009, 12:34 AM
