588,079 active members*
5,117 visitors online*
Thread: chatter
    Feb 2007
    505
    Cool chatter
    My home made cnc router is producing rough cut in wood always at the same spot ( 2 o`clock and 8 o`clock on a circle) the rest of the cut is nice and smooth.
    I suspect the width of my gantry could be the culprit, causing some binding when my router is working at both end of my Y axis.
    Is there a rule of thumb for the width of the gantry ?
    My table is about 2 feet on Y by 3 on X.
    May 2009
    3
    Try a new sharp cutter
    Jul 2008
    267
    Sounds like mechanical slop. See this post for pictures and solutions.
    http://www.mechmate.com/forums/showthread.php?t=1221
  1. boring bar chatter
    By chipproducer in forum MetalWork Discussion
    Last Post: 08-21-2017, 03:29 PM
  2. V-Carve chatter
    By Xnaron in forum DIY CNC Router Table Machines
    Last Post: 04-22-2009, 01:29 AM
  3. chatter on bore out
    By kendo in forum MetalWork Discussion
    Last Post: 12-17-2008, 03:26 AM
  4. chatter using mach 2
    By jtriggs in forum Mach Mill
    Last Post: 01-10-2007, 11:02 PM
  5. Chatter
    By gabeless in forum Hard / High Speed Machining
    Last Post: 07-14-2005, 05:09 PM
