603,365 active members*
3,894 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Cheap 1Amp microstepping bipolar driver using the PICSTEP.
Results 1 to 9 of 9
    Jan 2005
    364
    Have a look here how it all started:
    http://www.cnczone.com/forums/showthread.php?t=22867
    Attached is the PDF schematic for one axis.
    Here is a picture of a 3 axis PCB using the TEA3718SP:
    http://users.skynet.be/sky50985/CNC/..._tea/3axis.JPG
    Fit's nicely on a eurocard (100x160mm) but needs a double sided PCB.
    Single sided is possible but would need quite a few jumper wires.
    These TEA3718SP's can be recuperated from printer PCB's or even bought new for a few buck's each, a lot cheaper than LMD's if 1 Amp (or a bit more) is enough for your application.
    The concept of this R2R DAC can be used for other chips also.
    Suggestions and feedback are welcome.
    Regards,
    Luc.
    Attached Files Attached Files
    Apr 2009
    Pinout
    Hi Lucas,
    The pinout on your PDF does not match the Data sheet for TEA3718SP. Do you have an updated version of the schematic ?
    Jan 2005
    364
    sorry for the mess, this one should be OK.
    Can you please check it? Just to be sure.
    Thanks,
    Luc.
    Sep 2006
    18
    bipolar stepper driver
    Nice job ! This is exactly what i was looking for. I know thisnis an old thread, but i found it while searching for microstepping info, and i happen to have a bunch of salvaged a3952sw's i want to use.
    Im setting out to try building one based on your design now. ill be sure to post my results and diagrams. has any one else had any luck with other salvaged parts ?
    thanks !
    John
    Feb 2010
    71
    hello
    can i use this tehnique to drive Vref of l297.
    and parellel step and dir to pic and l297.
    i dont know if comparators in l297 used for chopping are fast enough for this, and how much clock i will need for chopper. can i go as high as 20khz on
    Jan 2005
    364
    No, this only works if there are 2 Vref inputs, one for each phase.
    Feb 2010
    71
    true. bu i need only waveform for current controll.
    phases will be ganerated by l297.
    waveform for dacs ( reisstor network are the same ) only shifted by 90 degres
    i read app note from ST and they stated that this can be done with l297 and l6208
    Jan 2005
    364
    It can be used with the L6208, this one has VrefA and VrefB input's.
    The step (clock) input may not be used, The change in Vref voltages will cause the motor to step.
    I don't see why a L297 is needed with the L6208.
    May 2005
    1397
    Love the PICStep, but I'm not all that impressed with the price on these drivers. I'm seeing $4-$5:
    TEA3718SP Stock and Price by Distributor | FindChips.com
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
