587,374 active members*
3,308 visitors online*
Results 1 to 11 of 11
    Feb 2011
    Cheap 3 Amp Stepper Driver
    I've got two old stepper motors for an old cnc lathe that need new drivers. the only specs i can find are:
    Powermax
    P22NRXC-LNN-NS-00:
    Torque: 238
    Resistance parallel: 0.78
    Current parallel: 3.1
    V: 2.418
    Watts: ~7.254
    Inductance parallel: 3.1mH
    What are some cheap drive options for a 3 amp stepper. Would a linistepper driver work?
    Jan 2005
    1943
    First, I am by no means an expert, just getting started onmy first CNC conversion, but have been doing a lot of research and have found that Gecko's are the cream of the crop. Your specs would indicate needing a driver that can give 56V and 3.1A. The Gecko G251 can do 50V at 3.5A. You would be a tad slower but it is much cheaper than the other Geckos at $69. Other options are the Keling drivers which I have read good things about, and the Chinese TB6560 drivers off E-bay. The TB6560 is only good to about 24V though. Below is a link to where you could buy the G251 or the Keling drives. For the Chinese driver search ebay for "single axis TB6560"
    http://www.automationtechnologiesinc...-motor-drivers
    May 2007
    380
    Skip the Chinese drives. If you have a problem, good luck! The bitterness of poor quality and customer service will linger long after the few dollars saved is forgotten. Go with Gecko and don't look back!
    Jan 2010
    2141
    Quote Originally Posted by aus10eww View Post
    How many wires do the motors have?
    The linistepper is designed to drive a unipolar motor (5, 6, or 8 wires).
    3 amps is on the high side of its range - if you were to put 3A through a linistepper you would want to have a hefty heatsink with a lot of air moving past it.
    Feb 2011
    The motors are 8 wire so the linistepper would work. What voltage would you recommend running them at?
    Jan 2005
    1695
    Linistepper is only good for up to about 1.5 amp. If you want best performance with those motors, you need around 48v.
    Jan 2010
    2141
    Quote Originally Posted by H500 View Post
    While it might be "wise" to limit the Linistepper to no more than 1.5 amps per phase, especially if your cooling is marginal, the documentation claims that you can go higher as long as you keep it cool enough.
    From LiniStepper, lini, stepper, linear, 6th microstep, linear microstepping stepper motor driver, constant current linear driver, circuit Linistepper boards, LiniStepper kit, hobby stepper, robot stepper driver kit, CNC stepper driver kit:
    If you require currents greater than 1.5A/phase you will need to
    change some parts values in the linistepper.
    The main transistors are rated for max 5A. They CAN be used for
    motor currents of up to 5 amps/phase. (You can even purchase darlington
    transistors the same physical size good for over 10 amps!)
    However using currents greater than 1.5A/phase will cause some headaches;
    * heat sensitivity increases (more temp drift)
    * much larger heatsink will be needed (more heat)
    * sense resistors will need to be larger wattage type (more heat)
    * microstepping tuning resistors need to be changed
    * you will need electronics skills and test equipment!
    I won't go into great detail here but it is viable to get up to 3A/phase
    from the linistepper but currents of 5A/phase etc are not very sensible.
    That page then goes into even more detail on considerations for running with high currents.
    Jan 2005
    1695
    Keep in mind this is a linear drive. To match the performance of my system, 34v will be required. At 3 amps/ph, that's 143W per motor, or 428w for 3 motors. Most of the power is wasted as heat.
    Jan 2010
    2141
    Dissipating a lot of heat in a linear driver is indeed a downside of the Linistepper, however it looks like the goal of the OP was to find an inexpensive driver solution, rather than to maximize performance, and so the Linistepper would be one way to meet that goal.
    I agree with you that the OP may not want to crank up the voltage too high on those puppies.
    Mar 2007
    28
    the keling 4030 will handle up to 3 amps, (I actually am using one on a 906 oz in nema 34 at 3.1 amps) they run about $40.00, I have been running them on two seperate machines, my X3 mill about one year, and my homebuilt IntraCut CNC 48 X96 machine for 6 years, I can't say enough good about these drives, they are inexpensive, reliable as the dickens, and the folks at Keling, now Automation Technologies Inc. have been as good as gold to me, and my brother. (I think they are reading my mind though because sometimes it seems they send me the tracking number for my order minutes after i place it, kinda creepy but worth it )
    All in all they are my first choice for inexpensive great preforming drives and motors
    (not a paid spokesman, it is just so rare these days to get good service that I think it is worth praise)
    Oct 2005
    2392
    The Linistepper is not a good choice for those motors due to the amps they require.
    The SLAmStepper will drive 3 amp motors and is a simple kit (since you asked about the Linistepper kit);
    SLAm Stepper Motor Controller, Allegro SLA7062M, Unipolar
    I use SLAms on my machine and I'm very happy with them.
  1. Cheap stepper motor controller and driver
    By webbyguy in forum Stepper Motors / Drives
    Last Post: 08-18-2010, 07:20 AM
  2. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
  3. Cheap, small, stepper Pic Driver II
    By Ragnarok in forum Stepper Motors / Drives
    Last Post: 07-02-2006, 03:40 AM
  4. Cheap, small, stepper Pic Driver - Developing
    Last Post: 06-02-2006, 08:39 PM
  5. Is there some cheap stepper motor driver?
    By ezland00 in forum CNC Machine Related Electronics
    Last Post: 03-26-2004, 03:20 AM
