587,272 active members*
4,610 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Cheap Linear encoders for position feedback
    Jan 2013
    228
    I am beginning to research converting my grizzly 1006 benchtop mill to CNC, It's in good shape and am planning to convert it.
    Is it possible to use the cheap chinese encoders for position feedback on a CNC mill? Like theseT23013 24" Remote Digital Readout, Inch/Metric/Fraction
    I have used these for a few different projects and decoding them is quite simple.
    Yuriy's Toys: Reading Gtizzly iGaging Digital Scales with Arduino
    21 Bit Protocol Scales | shumatech.com
    The are accurate up to .001". I have had some of these on my manual mill and they are still accurate.
    I understand eliminating backlash is for more than just position accuracy, but it seems like these could solve the accuracy issue.
    If someone has done it already could someone point me to a link where it's been done? After hours of searching I still can't find it.
    May 2006
    4047
    Hi TTalma,
    I don't have any experience with those but it would be pretty easy to try with our KFLOP Controller. Just pulse the clock 21 times and read in the position as a serial stream. We have a closed loop stepper mode that could use that as feedback. It looks like the update rate might be somewhat slow. I would love to see someone try it.
    Regards
    TK
    http://dynomotion.com
    Nov 2011
    21
    I haven't experience with subject, but it's good old idea. I saw in the Net small CNC 3 axis machine. Those guy used calipers for XY and Z travel 50mm(2") caliper free. Common problem is pretty low speed of DRO. Perhaps its useful up to 10-20 inch per minute. up to 500mm per min.
    I wish you good luck.
  1. any diy position feedback designs?
    By emorning in forum DIY CNC Router Table Machines
    Last Post: 05-03-2011, 04:39 AM
  2. cheap absolute encoders? Oxymoron? Decent Incremental encoders?
    By mattbesquare in forum Benchtop Machines
    Last Post: 09-09-2010, 12:56 AM
  3. Just saw a linear motor XY table with linear encoders today...nice
    By guru_florida in forum MetalWork Discussion
    Last Post: 04-29-2009, 01:39 AM
  4. DRO for position feedback
    By Bill Clark in forum CNC Machine Related Electronics
    Last Post: 05-05-2007, 12:40 AM
  5. good source for cheap glass scales/linear encoders?
    By mbwittig in forum Bridgeport / Hardinge Mills
    Last Post: 10-25-2006, 05:58 AM
