603,924 active members*
3,651 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Cheap MPG for CNC using optical mouse center encoder
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Apr 2003
    361
    I look forward to your working unit..:-)
    As for the z-axis, the precise control may not be necessary if a proper floating head is used for constant milling depth... drilling is a no brainer...
    Stupid questions make me smarter...
    See how smart I've become at www.9w2bsr.com ;-P
  2. #42
    May 2006
    2415
    I thought about that, but it is always nice to have a "smart" Z just in case it can be used for other purposes, possibly engraving small things, you never know...
  3. #43
    May 2006
    2415
    I have scored a couple of small DC motors that seem to be good quality, I am thinking of using these coupled to the linear encoder a la printer to make a small plotting machine, just for a test and see how suitable this would be for PCB making.
    This would just use some kind of floating head and maybe solenoid to raise/lower the head. More testing to follow...
    Russell.
  4. #44
    May 2003
    96
    I have 1 question as I too am building my own MPG controller, mainly for jobbing and centering purposes, therefore needless to say I want to have the commonly used buttons for such operation as well. Since I will be using 1 encoder to jog all axis, I am finding difficulty to allocate the setting to one of the buttons which need to toggle from one axis to another by "Alt A". I will also be using a second printer port which I have managed to set. Does anyone have any idea how to accieve this?
    Martin G
  5. #45
    May 2006
    2415
    Seems like the printer I had modded was thrown out in the last clean up (chair) no matter I will find another, it will just slow things down a little. Still keen to test the encoder resolution.
    Russell.
  6. #46
    Oct 2004
    hi
    coooooooooooool
  7. #47
    Oct 2004
    cool
  8. #48
    Feb 2008
    553
    Hi guys !
    Well, check this out, due to my poor electronics skills i couldn't follow my initial idea, a cheap hi res encoder.
    The wheel in the pic has 200 line per inch wich result in 1200 count per turn it encodes the printers main shaft, on the same printer, the print head encoder also has 200 LPI it is a linear encoder of approx 30 cm long.
    After frying the encoder module i can tell it is not an IR one, seems to be a simple led+sensor.
    Hope this helps !
    cnc2.
Page 3 of 3 123
  1. Cheap optical encoders
    By invertedflight in forum CNC Machine Related Electronics
    Last Post: 02-04-2008, 07:45 PM
  2. Turn an optical mouse in an XY encoder
    By NitroXide in forum Linear and Rotary Motion
    Last Post: 06-10-2007, 10:02 PM
  3. Optical encoder index - what is it good for?
    By medved in forum CNC Machine Related Electronics
    Last Post: 10-03-2005, 11:26 PM
  4. easy tacho or encoder: cny70 reflective optical sensor
    By gcamlibel in forum CNC Machine Related Electronics
    Last Post: 10-12-2004, 08:38 PM
  5. Optical Encoder Differential Line Driver
    By azsigns in forum CNC Machine Related Electronics
    Last Post: 03-04-2004, 10:41 AM
