IGES-LINK
OVERFLOW, DO NOT CHECK ALL ENTITIES AT ONCE
When I try to import an iges file of a part model. I receive this message. How do I correct this. Im working with Level 1 AS3000.
IGES-LINK
This message "OVERFLOW DO NOT CHECK ALL ENTITIES AT ONCE" is saying that memory has been exceeded because there are too many entities in the IGES file. Entities are individual points, lines, arcs, circle etc...
This message is suggesting to reduce the number entities by not checking all of the IGES options at once. There are a variety of options and combinations on the IGES import window as well as many different IGES flavors over the years.
From what you wrote "Part Model" and working with "AS3000 Level-1" what is most likely happening is that the part model is either a solid model or else contains 3D Surfaces. In either case Level-1 doesn't support these. You would need to upgrade to Level-20
Tech Support
CamSoft Corp.
[email protected]
PH 951-674-8100
Fax 951-674-3110
CNC Controller, PC Based CNC Controls
