603,321 active members*
3,406 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > China Turbine Zhongneng Turbine Oil Purification/Oil Purifier/Oil Filtration
Results 1 to 1 of 1
    Sep 2006
    8
    Zhongneng Turbine Oil Purification (oil purification, oil purifier, oil filtration, oil filter, oil purifier, oil recycling, oil treatment, oil regeneration, oil restoration, oil filtering, waste oil disposal, oil reclaiming, waste oil management, energy saving, oil reconditioned, oil reconstituted, oil restituting, oil recovering)
    Application
    It is used for treating the unqualified turbine oil, especially the seriously emulsified turbine oil. This products, which can rapidly and effectively remove the water, gas and impurities, aim at turbine oil’s nature of high water content, easy emulsifiable and high impurity content and make the oil recover the new oil’s nature.
    Features
    1. Breaking emulsification thoroughly with high- molecule polymeric material.
    2. Dewatering very effectively with once and for two steps dehydrating method. It can thoroughly clear away the liquid water, free water and 80% dissolved water.
    3. With distinctive removing impurities technique filtering through double FH trapezoidal network and absorbing by high polymer material, this machine can make the ß3 equal or surpass 200 and make the cleanness lower grade 6(NAS1638).
    4. With the trapezoidal, spiral, automatic back flushing system.
    5. With the advanced dielectric condensation devices.
    6. On-line oil purification can be carried out with turbine or water turbine automatically without any person.
