Originally Posted by
handlewanker
Just had a look at the listing on Amazon and it is the XSY-AT1 model.
There is a red and green button on the front.
The green is labelled run and the red stop/reset......it also has the round speed control knob.
I assumed the red button was the stop button......why would you need a disconnect between the VFD and the wall socket....to totally isolate the VFD when the work is over?
In OZ all of our wall sockets are switched, but I definately would not stop the motor by switching the VFD off at the wall socket.
What effect does the red stop/reset button have, apart from stopping the driven motor......that is, what does the reset function do?....I see it also has a function button too.
I got the impression, if my memory still functions, that the red button stops the motor with a single stab at the button and a long press enables the parameters to be re-set with the up and down arrow buttons......maybe not, I think the function button does all that.....I'll have to gen up on it.
Ian.
