588,156 active members*
5,070 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > CHINESE BALL SCREWS- HOW TO RE-LOAD?
    Feb 2009
    152
    Hi-
    I have an early model Shopmaster Patriot with acme lead screws. I bought some Chinese ball screws on E-Bay, but I need to take the ball nut off and turn it around 180 degrees on one. I'm not sure how to re-load the balls into the nut. These ball nuts have seals on each side and 3 plastic buttons spaced about 120 degrees apart - I'm wondering if this is where you would re-load the balls.
    Thanks in advance for any help.
    Mar 2010
    115
    I don't have a direct link, but there is a really good video on YouTube showing how its done. Not something you can easily describe it hour seeing it!
    Just search for ballnut repack or similar words.
  1. Chinese C7 vs Roton Ball Screws
    By hive8 in forum Benchtop Machines
    Last Post: 06-18-2012, 02:26 AM
  2. Question about the chinese ball screws....
    By gearsoup in forum Linear and Rotary Motion
    Last Post: 10-06-2010, 11:25 PM
  3. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  4. Actual load on Ball Screw?
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 10-22-2004, 05:05 PM
