603,388 active members*
2,782 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Chinese CNC 3040T Fusion 360 postprocessor
    Question Chinese CNC 3040T Fusion 360 postprocessor
    Hello,
    i have a problem with exported gcode from Fusion 360:
    if i select Mach3mill as posprocessor the Z axis doesen't rise up before it starts to mill, so the endmill bit will crash in the object.
    I use the provided USB Software and i don't know wich postprocessor i have to select.
    Can anyone help me?
    Thank You.
    Mar 2016
    45
    Re: Chinese CNC 3040T Fusion 360 postprocessor
    When you run your simulator in 360 does is flash red , also in mach post scrip you may need to change some settings. When I get home I'll post my mach3 script settings
    Quote Originally Posted by neolinux View Post
    Hello,
    Can anyone help me?
    Thank You.
    Sent from my Nexus 6 using Tapatalk
    I found a solution:
    i generate the gcode selecting the Mach3mill postprocessor, then i home all the axes, i rise the Z axis 1-2cm above the piece to mill and then i start milling.
    Is there any modification to the postprocessor that i can make to rise the Z axis automatically? The thinyG postprocessor does that, but i use Mach3 or the provided Software.
  1. Newbie with a Chinese 3040T CNC
    By tallen1962 in forum Chinese Machines
    Last Post: 01-29-2017, 10:44 PM
  2. Chinese 3040T
    By joe winslow in forum Community Club House
    Last Post: 01-21-2014, 08:53 PM
  3. Chinese 3040T for acrylic?
    By Pwnography6 in forum Chinese Machines
    Last Post: 11-29-2013, 04:34 PM
  4. Chinese 3040T H80 engraver spindle speed control - help
    By tiffyted in forum European Club House
    Last Post: 11-19-2013, 11:57 PM
  5. Chinese CNC 3040T Slow Spindle Motor
    By Viking50 in forum Chinese Machines
    Last Post: 09-05-2013, 07:06 AM
