603,965 active members*
2,479 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Chinese Cnc router won't initialise and all 3 stepper motors just stopped working.
    Mar 2019
    5
    I have a Chinese router running Cnc planet. It's worked flawlessly for 2-3 years, then coming back after lunch, nothing. No jog. The program runs but the machine is down. Xmas means big trouble - no deliveries = no spares. Don't know if it was / is the cable or the breakout board. Assuming it's the breakout board (integrated with the drivers), it is dead.
    I have another smaller machine, with a separate (working) control box but
    I believe it is a USB pc out to parallel input. With no instructions on the DIP settings, it was quicker for me to transfer motors. Now the homing menu etc is all greyed out. At least I now hear a motor hiss but the software won't initialise and so again it won't run the steppers.
    I've tried both a parallel cable and the USB/ parallel.
    It has to be REALLY simple but I can't work it out.
    Suggestions?
    Jun 2020
    18
    Re: Chinese Cnc router won't initialise and all 3 stepper motors just stopped working
    Hello,
    Has your problem been solved? I once saw an article about engraving machine faults and solutions on a website. If you are interested, you can go and read it. I hope it will help you: https://forsuncnc.com/cnc-routers-co...and-solutions/
  1. CNC Router Machine - Z axis stopped working
    By fletch123 in forum Australia, New Zealand Club House
    Last Post: 07-27-2020, 10:52 AM
  2. Dq542a stepper driver stopped working
    By ciarancub83 in forum Stepper Motors / Drives
    Last Post: 01-01-2019, 04:00 PM
  3. Soo close I can smell it (motors stopped working)
    By tubby in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-15-2016, 05:57 AM
  4. Mach3 stopped, board doesn't initialise.
    By jimini in forum Machines running Mach Software
    Last Post: 12-20-2013, 06:39 PM
  5. Spindle motor stopped, stepper motors flaky...
    By americanbehn in forum DNC Problems and Solutions
    Last Post: 11-06-2007, 03:25 AM
