588,209 active members*
4,407 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Chinese scales to position the tool
Page 3 of 4 1234
Results 41 to 60 of 75
  1. #41
    Mar 2007
    534
    Quote Originally Posted by eightball View Post
    Robin, I'd love to hear some more updates/progress on the system you're working on
    Thanks for resurrecting this thread I thought I'd lost it
    Having figured out that the PC needs to do a lot more of the work if it is to tweak what's happenning on the fly, I reworked the circuit boards to remove a few annoyances, dump some unnecessaries and added a port to drive a digital inverter.
    Then I reworked the milling machine with SSR's for the main motor and suds pump so I can switch them over to software control. I put everything inside the door of it's cabinet for easy access.
    Next I have to mount the scales and plug it all in.
    I'm going to have to drive it through a USB adaptor if it is to have any hope of working under XP. Bill Gates can't even keep up at 9600 baud for long even with FIFO's enabled.
  2. #42
    Mar 2007
    534
    Quote Originally Posted by mikehg1 View Post
    Is that some type of universal proto board ? Seems like a LOT of connectors on there!
    You need a lot of plugs for the malarky
    3 stepper drivers, 3 digital scales, 1 port to drive motor/suds/etc, 1 PC interface.
    Then I have my 3 auxilliary ports for pligging in pendants, stops, tool locators, whatever, and now an extra RS232 for the motor inverter.
    Did I forget anything?
  3. #43
    Jun 2008
    18
    i dont think the usb adapter is gonna help you achive higher transfer speeds if thats what you're looking for. Im pretty sure you're always gonna be limited to the speed of the serial controller on the device side. might be worth it go go full on usb and grab a usb2 mc
  4. #44
    Jun 2003
    2103
    Quote Originally Posted by Robin Hewitt View Post
    Not really sure I know what I mean either
    Here's the idea I had...
    I've been positioning the milling table by turning the leadscrews very precisely and trying to minimise backlash, it works okay.
    I had a notion that if the milling machine could read the table and quill positions independantly of the screws, it could position it a lot better.
    So I'm making a computer board that accepts g-code, reads the scales, turns the handles, plus a few other things that I think might be fun such as a pendant, tool height and X,Y absolute position gauges.
    It's okay to tell me that it's already been done and is available for 50 bucks from Geekware Inc. I won't mind
    It's already been done and available for 50 bucks from Geekware Inc.
    I'm sorry, but I just couldn't pass that one up. I can tell you that not only what you have planned has already been done, but done using dual encoder feedback on 6 axis with position correction on the fly! It is not 50 bucks though! I will tell you this though, I have seen a video where the developer places his hand on his mill and pushes on an axis and you can hear the steppers moving to correct the position, then when he takes his hand off, you can hear them correct again.......or I should say, you can hear them end correction!
    BTW nice work!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  5. #45
    Feb 2005
    14
    Quote Originally Posted by turmite View Post
    Mike
    Do you have a link to the website you mention above?
    hennie
  6. #46
    Mar 2007
    534
    I don't need faster than 9600, I could probably work on less. What I want is a buffer so it doesn't lose information when Windows doesn't service the interrupt fast enough to receive my status block without holes in it.
    IIRC USB works with a shared memory block so a buffer is implied. Hopefully big enough. I don't need much.
    Downloading is fine. When I have room for more pre-digested G-code I point the serial input interrupt where I want the data to go and ask for 8k blocks until my buffer is full. I don't care if it arrives in one great lump, I can keep up
  7. #47
    Aug 2006
    1602
    You might have trouble with USB's latency if you are trying to get real-time position information into the PC. A serial port may not have much bandwidth, but it does have a small and predictable latency, assuming your PC's not busy doing something else real-time.
  8. #48
    Mar 2007
    534
    Quote Originally Posted by digits View Post
    Fortunately the replies to the PC are only for drawing a picture on the screen and setting options. This only works (hopefully) because the scales and stepper drivers are both on the same dedicated cpu. Even so the steppers will get ahead of the scales which only report 50 times a second, dismally slow when you use lots of steps/inch.
    I'm off to my workshop to continue wiring up the mill with it's new switch panel. Last time I did it I didn't know what controls I would actually want/use, with hindsight I want 5...
    Main motor on/off
    Suds pump on/off
    Suds flow rate
    auto/isolate/manual
    and one to kill the steppers so I can do it the old fashioned way
  9. #49
    Aug 2006
    1602
    Main motor on/off
    Suds pump on/off
    Suds flow rate
    auto/isolate/manual
    IMHO, that's definately the way to do it - you want dedicated real-time H/W on your machine and just a PC to monitor and command it.
    Happy tinkering!
  10. #50
    Jun 2008
    18
    Main motor on/off
    Suds pump on/off
    Suds flow rate
    auto/isolate/manual
    I also planned for a couple additional switches...
    lights - main halogens, spindle led ring light
    lasers (for centering/aligning using 2 line lasers, mount on either side of the spindle and where the 2 lines intersect is where the center of the bit/endmill will make contact)
    mist coolant -(3 way rocker switch) always on(opens air and coolant solenoids), off, manual control (turns the air solenoid on and activates foot trigger for activating the coolant solenoid)
    Flood coolant - on/off
    this is sort of a wish list, i only have about 1/2 these things ready to be plugged in to the control panel
  11. #51
    Mar 2007
    534
    It's coming on well, looks a lot tidier, have a before and after pic
  12. #52
    May 2007
    1026
    Thinking about the challenges of the 50x second update cycle... So, just out of curiosity, what is the goal of the system? From where I sit I see four possible gains versus a typical open-loop system:
    1. Remove backlash from less-expensive linear positioning systems
    2. Reliably run motors very close to their torque limits
    3. Compensate for lead screw inaccuracies
    4. Replace home and limit switches
    There's also the "it's cool!" reason which is usually sufficient
    Anyway, from where I sit it seems like #1 would do the most good followed a distant second by #3. As I understand it, steppers are 100% reliable assuming that you stay within their torque capabilities, and "proper" limit switches are designed to work outside the control loop for safety, so those two are somewhat moot.
    Point being, if all you wanted to do was to reduce backlash, then couldn't you essentially ignore the scale position except on the way in and out of an axis reversal? As you approach one you could slow down to within the realtime sensing resolution and then accelerate back out of it.
    Lead screw accuracy is another issue but can also be compensated for by measuiring the screw and building a deviation table. This does create a lot of additional things for the software to do, but if the sensing interval were to prove problematic, it might be a way out.
  13. #53
    Mar 2007
    534
    Quote Originally Posted by sansbury View Post
    The goal is to wring every last drop of precision to be had from a cheap Chinese mill/drill combo fitted with ball screws. I'm hoping the scales will tell me what needs to be done
  14. #54
    Jun 2003
    2103
    Quote Originally Posted by cozymkiv View Post
    hennie
    I do, but I don't have permission to post it since it will be announced here hopefully early this week. I will try to get permission to post a video but that will strictly be the developer's call.
    Mike
  15. #55
    Mar 2007
    574
    Mike
    well 2 month later we are very interested because a dual encoder interpolator for 50 us$ and even if it does only that it's great
  16. #56
    May 2005
    1662
    Quote Originally Posted by rokag3 View Post
    turmite posted "it will not be $50 though". Fairly certain the discussion can be found here
    http://www.cnczone.com/forums/showthread.php?t=59763
    A couple of members here (possibly more?) have the device. No cnczone member except the developer making chips with it so far to the best of my knowledge. It's early days.
    Anyone who says "It only goes together one way" has no imagination.
  17. #57
    Mar 2007
    534
    One intersting feature of the Chinese scales is that the metalwork connects to the positive side of it's battery. Makes for some interesting accidental circuits if you don't isolate it from the machine
  18. #58
    Sep 2006
    607
    Just wanting to check if theres anything happening to this project.
  19. #59
    Mar 2007
    534
    Quote Originally Posted by The Blight View Post
    Well, I ripped it up and started again twice, then I hit a bug which stopped me for a few weeks... I was turning on and applying the accelerations BEFORE data actually reached the step interrupt. The timer reload setting overflowed and everything went to hell in a handbasket.
    While finding the bug I found several other potential nasties so the code is currently running sweetly. I am sure I will soon change all that.
    Then came Christmas and I had to do other things, still busy and I will need to see a few weeks clear for programming before I put this program back in my head and get going again.
  20. #60
    Sep 2006
    607
    I'm glad to hear that you are working on it! I have been looking into those cheap scales myself, but as a way to check that if the position is correct. What you are doing is a lot more advanced. Have you been thinking about making your own controller for the caliper? I found the signal it sends out to be junk. It can be used, but it's messy.
    And you are damn stubborn! Thats a good quality!
Page 3 of 4 1234
  1. Chinese machine tool show set for 2007
    By r.hung in forum Trade Shows / Webinars / Other Events
    Last Post: 07-28-2006, 07:08 AM
  2. Tool position indicator
    By Jalex in forum DNC Problems and Solutions
    Last Post: 06-24-2006, 07:25 PM
