587,865 active members*
3,152 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > chinese spindle question(s)
Page 1 of 2 12
Results 1 to 20 of 21
    Sep 2010
    183
    Hello All,
    I have been running a 5x10 for a few years now. I bought a decommissioned commercial router, less the z drive and any wiring. With the help of this forum I got it put together and have been making sawdust ever since.
    I raised the gantry so I have a 7" z, and finally bought a 10HP vacuum pump. Its been extremely reliable and has become an integral part of feeding the family.
    I have been running a porter cable 7518 router motor. I can't say enough about it. Its been a beast. I believe I'm on my 4th set of brushes. Its been running for some 5 plus years on a regular basis. I can't count the number or 3/4 sheets of MDO and MDF I've cut with it. I have also cut a few hundred a/b long board and skateboard molds among tons of other projects. I don't feel it owes me much. The bearings are starting to get tight and I can't reliably use it any more. I have had this sitting around for a while-
    I'm sorta at the point that I have out grown my router. I don't want to put much $ into it. I need a ATC and more power all around. So for now I want to install the 3KW Chinese spindle. I have a piece of scrap 3/8 aluminum and a Bridgeport so installing it should only cost cable and a few screws.
    I have no manuals or way to ID this stuff. I know it's a 3 kw Chinese spindle and a Huanyang VFD .
    I tried the factory parameters and the spindle would start to ramp up (spin) then stop and the VFD would read "LU"
    I looked all over and tried a few specs for the 2.2 and other random "PD" parameters. Nothing helped.
    Here is what I have so far-
    PD001=0
    PD002=0
    PD005=400
    PD004=400
    PD003=400
    PD141=220
    PD142=11
    PD144=2000
    PD008=220
    PD013=0
    PD072=400
    I have tried a number of other settings..
    Any insight would be great!!
    R=hot
    S=hot
    T=Neutral
    U,V,W poles on motor
    9 ground
    Thank you for your time.
    Vince
    Jan 2005
    15362
    Re: chinese spindle question(s)
    Quote Originally Posted by vpl View Post
    Hello All,
    PD001=0
    PD002=0
    PD005=400
    PD004=400
    PD003=400
    PD141=220
    PD142=11
    PD144=2000
    PD008=220
    PD013=0
    PD072=400
    R=hot
    S=hot
    T=Neutral
    9 ground
    Vince
    The first red flag I see is you have the neutral wire connected, you can not do this this will damage the VFD Drive, need more spec's on the spindle to know if you have the parameters set correct
    So your wiring has to be changed, R and T Hot on R Hot on T and Ground to the Ground terminal, Neutral is not used with 240v NA Supply, Remove the NEUTRAL WIRE is this air cooled
    Mactec54
    Sep 2010
    183
    My first assumption was not to use the neutral wire. I tried it without to start with and had the same issue-
    Thanks for looking.
    Jan 2005
    15362
    Thanks for looking.
    Is the spindle air cooled ?? you don't have all the parameters that are needed to run this spindle, what is the max output amps of the VFD Drive
    Mactec54
    Sep 2010
    183
    I think you answered my question.
    When I try to modify PD142, which I understand to be motor current in amps it only goes to 11, it was set at 10 for a 2.2 kw. I assume I need at least 13.63 according to an online calculator. I bought the pair on ebay as a set some years ago. Is there an other parameter that controls or influences the PD142 setting? Or is this VFD simply the wrong one?
    Thanks for your time
    Sep 2010
    183
    The removable cover says it's a 220V/3.0KW. I looked on ebay and it seems for the 2.2kw the VFDs are rated at 10amp, the 3.0kw at 13 amps.
    Can I change a parameter that will allow more than 11 amps? Is 11 amps enough? Thanks
    Jan 2005
    15362
    No you have to have the right size VFD Drive, the drive will run it but won't last a long time, you need a 4Kw for that 3Kw spindle
    What does the name plate say on the VFD it will tell you there what it's max output Amps are, if it is rated for higher Amps then there is a way to change it, but not if it is not rated for a higher output
    Is this a 400Hz spindle or a 300Hz spindle, these both require different parameters
    Mactec54
    Sep 2010
    183
    There is no info anywhere other than a high voltage warning on the vfd-
    There is nothing on the spindle itself. Like I said I bought it years ago as a set on ebay. It came with zero documentation.
    I'm not sure what direction to take.
    Anyone have vfd parameters for a 3K spindle?
    Jan 2005
    15362
    I have all the parameters that are needed, but you need some information from the spindle, that I just asked you, is the spindle 300Hz or 400Hz, or what is the max RPM that will tell me the Hz it is, if it not not on the spindle name plate
    Mactec54
    Sep 2010
    183
    mactec54,
    Thank you for the help.
    Attachment 383776
    Attachment 383778
    Attachment 383780
    Attachment 383782
    Maybe this can help ID my spindle. I simply can't remember what was advertised as max rpm. There really aren't any tags, badges, UPC, or any useful info other on either unit other than the 220V/3.0KW sticker on the vfd
    Attachment 383784
    Nothing on the sides, back or under the cover for info on the vfd
    If you have a guess as to what the specs are you're ahead of me-
    Jan 2005
    15362
    Vpl
    Try this to start with, make sure the wiring is correct, your spindle may be only 18,000 RPM most of these air cooled where, so this is a starting point
    The VFD could be faulty, if these Parameters don't get you going
    Huanyang Mactec54
    2.2Kw Air Cooled
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Terminal Control )
    PD003=300
    PD004=300
    PD005=300
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=200
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=12 ( Adjust to suit)
    PD015 Deceleration=12 (Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage )
    PD142= 9 ( Motor Max Amps)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (18,000 or 24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=300
    PD73=200
    Mactec54
    Sep 2010
    183
    Vpl
    Huanyang Mactec54
    2.2Kw Air Cooled
    PD003=300
    PD004=300
    PD005=300
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=200
    PD72=300
    PD73=200
    Thank you sir-
    I'll give these a shot today-
    I see it's for a 2.2kw. Is that okay with my 3.0kw? I would assume the PD142 number should be higher??
    I'll let you know the outcome.
    I believe you stated earlier that this unit is under rated or won't last long. What would you suggest?
    Feb 2009
    95
    Air cooled spindles are usually 300 Hz (18 000 rpm) max but also have lower minimal speed than the water cooled. Can't remember the exact value.
    Jan 2005
    15362
    Thank you sir-
    Yes if it is going to run, this will get it going, we will look at what we need to do, to the VFD to make it play nice, for the higher amps, Etc and may be fix the Lu if it still happens, this I will give to you in a PM
    Try the VFD by it's self, as well, no spindle connected, if you still get the fault, then we will take a look at some special Parameters to change
    Mactec54
    Jan 2005
    15362
    Quote Originally Posted by Dragonfly View Post
    200 Hz is a good starting point for the minimum RPM when using these air cooled spindles, you can adjust this parameter lower, and check the spindle motor temperature, does not rise above the full speed running temperature, which is normally around 110 deg F to 120 deg F
    Mactec54
    Sep 2010
    183
    Okay thanks for the parameters.
    This is what I have found. I swapped in your parameters. Now if you hit run without the spindle wired you can watch the vfd build rpm. When you hit stop it spools down. Both operations take the prescribed 12 seconds.
    Hook the spindle up and it begins to start & gets to about 500-1,000 rpm and quits, throws the LV code.
    Any thoughts?
  17. #17
    Jan 2005
    15362
    Any thoughts?
    How many amps is you main power supply??? you will need at least a 30Amp supply
    It seems the VFD may be OK, If you have a good power supply, then we will move to change some special Parameters
    Mactec54
  18. #18
    Sep 2010
    183
    Mactec,
    I have it wired into a plug that runs a 50 amp breaker. I checked the voltage, each leg is 120 to ground, 240 between the two legs using an old analog VOM.
    Parameter time??
    Vince
  19. #19
    Jan 2005
    15362
    Mactec,
    Parameter time??
    Vince
    Ok that sounds good, I will put together what you have to do
    Mactec54
  20. #20
    Jan 2005
    15362
    Mactec,
    Parameter time??
    Vince
    PM sent
    Mactec54
Page 1 of 2 12
  1. Replies: 7
    Last Post: 11-05-2015, 03:38 PM
  2. Chinese 1.5kw spindle runout question
    By Power_user_EX in forum Spindles / VFD
    Last Post: 03-19-2014, 12:25 AM
  3. Chinese 3KW spindle + Hitachi VFD question
    By mercaytor in forum DIY CNC Router Table Machines
    Last Post: 11-28-2013, 02:57 AM
  4. Transformer for 2.2 KW chinese spindle question?
    By bao84 in forum DIY CNC Router Table Machines
    Last Post: 12-01-2012, 04:51 AM
  5. Yet "another" Chinese Spindle Question
    By Bob La Londe in forum Maintenance DIY Discussion
    Last Post: 02-14-2012, 11:31 PM
