603,370 active members*
3,666 visitors online*
    Aug 2015
    Chinesse Machine, need a stamp software
    I have a problem with rubber stamps, they do not fit because it does degraded at the edges of the cut. I use corel plugin.
    I have 2 programs, the moshidraw and winsealxp with the USB keys.
    I can use any of the programs to make rubber stamps? or there is a specific program for that?
    thousand thanks
    Tengo un problema con los cuños de caucho, no quedan bien porque no hace degradado en los bordes del corte. Utilizo plugin de corel.
    tengo 2 programas, el moshidraw y el winsealxp, con las llave usb.
    Puedo utilizar alguno de los programas para hacer sellos de caucho ? o hay algun programa especifico para eso?
    mil gracias
    Sep 2013
    Re: Chinesse Machine, need a stamp software
    Moshidraw 14 : In the FavoritesOption folder? I believe if you use Versa and Concave settings will work but you may have to set Outline on in the OutputType.
  1. Newest design stamp laser engraving machine SIN-20U
    By gaosinicnc in forum News Announcements
    Last Post: 11-21-2013, 09:04 AM
  2. Newest design stamp laser engraving machine MT20U
    By RoseChina in forum News Announcements
    Last Post: 05-28-2013, 10:43 AM
  3. I can't engrave Rubber Stamp with my CO2 40W laser machine
    By jclurdaniz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-12-2013, 04:38 PM
  4. Can I engrave Rubber Stamp with 40W machine
    By jclurdaniz in forum European Club House
    Last Post: 07-04-2011, 06:22 PM
  5. HX3040 Stamp software?
    By CanAm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2009, 02:06 PM
