588,030 active members*
4,515 visitors online*
Results 1 to 10 of 10
    May 2005
    2502
    Chip and Coolant Splash Guard
    I came across this on eBay (Item # 330322169625 , seller cncm3x). It's a nice looking chip and coolant splash guard. Here is a photo of it installed on a knee mill:
    From the rear:
    The rear wall is rubber, which I don't think is going to work out with a bed mill, so I would look to put very short sheet metal pieces on the ends.
    It mounts directly to the table using the normal T-slot locations as far as I can tell:
    This guard is designed for a 9" x 42" table on a machine with 12" travels. The IH has a 9.5" x 39.5" table and has 12.5" Y travel. Those differences looked to me like something I could make work, so I ordered one.
    I might prefer a full enclosure at some point, but this one looked pretty nice, and the price of $279 didn't seem to bad. They want $500 for one on their site. You could fab one pretty cheap if you have a brake.
    My shop has started picking up a fine layer of aluminum chips everywhere. It's amazing how many chips one of these CNC mills will throw off. I need some way to get it under control and this seems pretty quick and easy.
    I'll report back when I get it on what it takes to fit it to the IH mill and how well it works.
    Cheers,
    BW
    Feb 2006
    794
    I got a full enclosure and I get chips and coolant dripping off of it all the time ! That thing is going to be virtually useless !
    Don
    IH v-3 early model owner
    Jun 2005
    1015
    i built one that is twice as tall. i'll try and get some pics later.
    Sep 2008
    73
    Great price and looks good. The sides sure could be higher.
    Evan
    Mar 2010
    Nice setup. Looks easy to make.
    Feb 2010
    3447
    Re: Chip and Coolant Splash Guard
    well how did it work out and fit?
    Jun 2013
    41
    Attachment 248854
    We are now offering these table top enclosures. With the addition of a drain hole in the table, they are exceptionally functional and actually work for containing the majority of the coolant. The sides and back are adjustable to achieve maximum splash resistance.
    Oct 2010
    1189
    I had similar Setup did not work so i designed a full enclosure ...
    Feb 2010
    3447
    Any pics?
    Oct 2010
    1189
    Hi
    i documented it here http://www.cnczone.com/forums/genera...iteration.html
    so there are pics -
    due to vacation i had no time to Finnish the covers on the machine which i will do the next 2 weeks
    thomas
  1. Splash Guard
    By AVRnj in forum Tormach Personal CNC Mill
    Last Post: 04-16-2014, 03:05 PM
  2. New Table chip/coolant guard
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 01-22-2014, 09:48 PM
  3. New, improved splash guard
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 02-09-2013, 05:48 PM
  4. New splash guard
    Last Post: 03-17-2012, 02:01 AM
  5. Splash Guard for HF 8x12
    By jk080 in forum Mini Lathe
    Last Post: 01-13-2008, 02:01 AM
