587,770 active members*
3,092 visitors online*
IndustryArena Forum > Community Club House > Chipping melamine edge during a cut.
Results 1 to 6 of 6
Hybrid View
    Feb 2004
    2337
    I am cutting melemine laminated chipboard ( 16mm) and it is chipping along the bottom edge of the board. I am using a 1/8th straight bit. The bit is new and sharp.
    It has been suggested I use a chip breaking bit after my initail cut but that sounds like it would be impractical for me since I dont have a tool changer and dont really want to do the same cutpath a second time.
    Any suggestions.
    Being outside the square !!!
    Mar 2003
    6855
    You could try to apply tape, or if you can score the bottom before you cut through that would work to. I use to work at a exhibits company building exhibits, usually routing did'nt cause chipping but cutting with a saw blade did, depending on the type of blade used.
    Apr 2003
    470
    How about taking a finishing pass? Have you tried a spiral endmill? (That'd move the chipping to the top maybe.) Climb cutting? (on a finishing pass that'd probably not chip out on both sides. I've cut a little of this stuff and thats what I ended up having to do.
    Nathan
    Mar 2003
    6855
    They do sell a special bit the cuts up and down, for melamine.
    "Three flutes upcut & three flutes downcut. This tool was designed with extremely high feed rates in mind. Primary usage on double laminated particle board. Secondary usage suitable for finish cuts in solid wood and other dense materials."
    Mar 2003
    35538
    You need a compression spiral, Benny. I use these at work. http://www.vortextool.com/standard/p...fm?groupID=273
    You can find cheaper ones, but these are the best I've used.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2003
    35538
    Do you have to use a 1/8" bit? A larger bit will probably cut cleaner due to less deflection and chatter.
    Gerry
  1. Kcam Cut depth
    By 47MLB in forum Uncategorised CAM Discussion
    Last Post: 01-18-2012, 08:04 PM
  2. rotary 4 ax depth of cut q.
    By nervis1 in forum Mastercam
    Last Post: 03-24-2005, 11:34 PM
  3. cut single, cut auto and cut all???
    By fastolds in forum BobCad-Cam
    Last Post: 10-06-2004, 02:15 PM
  4. PICS - BOAT HULL CUT WITH CNC
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 08-03-2004, 12:21 AM
  5. Can you cut Al. with a wood bandsaw
    By CactusChip in forum MetalWork Discussion
    Last Post: 11-20-2003, 10:45 PM
