603,369 active members*
2,834 visitors online*
    Chiron FZ12 with siemens 810M . Softkeys not working.
    Hi ,
    I own an old FZ12 which was manufactured in 1987.
    The serial number of the machine is FZ12 number 101-18.
    The serial number of the Sinumerik is ,
    Sinumerik 810 M,
    6FC3471-OAA-Z
    F-NR.:A 1477149
    24 V DC 120 W
    When our machine is powered up we get an alarm message "12 ORD1 PP memory wrongly formatted"
    The symptoms are
    1/ The softkeys will not work.
    2/ It IS possible to reference the machine
    3/The Swarf elevator is on permanently. The switch does not turn it off
    4/ The coolant pump switch works correctly and goes on and off.
    5/ None of the other buttons or switches on the upper panel work.
    Can anyone suggest what may be wrong?
    Here are links to 2 videos which may help in identifying the problem.
    https://dl.dropboxusercontent.com/u/.../VIDEO0031.mp4
    https://dl.dropboxusercontent.com/u/.../VIDEO0032.mp4
    Apr 2015
    Re: Chiron FZ12 with siemens 810M . Softkeys not working.
    I have seen this problem before, you need to press the eyeball button to get to the service menu, enter password (default: 1111) and find the "clear PP" option.
    May 2014
    18
    Beware if you go to the initial clear mode, if you erase to much you need to reload TEA1, TEA2 and PCP files. Make sure you have them.
    In official Siemens book error 12 states:
    -Error in RAM area of CPU or memory module
    -The minimum size of the part program was not reached
    -Module withdrawn
    -Check MD12 and depress "clear partpr" softkey (bit hard if softkeys don't work...)
    Hope this helps you in any way?
    Gr
    Bart
  1. Siemens 810 on Chiron FZ12
    By Rotormac in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-31-2024, 07:56 PM
  2. Chiron FZ12W High speed Siemens 810m error codes
    By efret in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 10-15-2022, 08:36 PM
  3. Chiron FZ12 W Fanuc 21MB
    By singist42 in forum Fanuc
    Last Post: 04-08-2014, 04:10 PM
  4. Siemens 810M Communication. help Needed
    By mjhjenks in forum DNC Problems and Solutions
    Last Post: 07-04-2010, 05:42 AM
  5. Siemens 810M initialization
    Last Post: 02-16-2009, 04:16 PM
