587,974 active members*
4,295 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > "CHIRP" at tool change
Results 1 to 5 of 5
    Aug 2017
    8
    Hi guys
    Im sure someone has experienced this.
    When my Fadal goes to a tool change it makes a high pitch chirp.
    It seems to do it when the tool clamps
    I have taken the tool out and just manually press and depress the Tool in / out button and it makes this chirp.
    Look forward to your reply
    Feb 2011
    423
    Re: "CHIRP" at tool change
    Kinda sounds like the muffler has been removed from the valve on the drawbar assembly.
    Jan 2015
    417
    Sounds like it is the Muffler on the tool in/out piston. if the muffler was removed it sounds like a .22 caliber revolver being shot
    Aug 2017
    8
    Thanks for the help.
    I have a new muffler on order..
    Cheers
    - - - Updated - - -
    Thanks for the help....
    Aug 2017
    8
    Ended up being the input air pressure was "TOO MUCH"
    Running fine as I have lowered it to 80-90
    Thanks again
  1. morbidelli/ author 667 "PLC30 Cycle Tool Change"
    By Raptorjesus806 in forum CNC Machining Centers
    Last Post: 01-22-2018, 10:49 PM
  2. Blue screen tool change macro "off"
    By Herptastic in forum Mach Wizards, Macros, & Addons
    Last Post: 01-09-2017, 01:43 AM
  3. Replies: 2
    Last Post: 09-29-2016, 06:59 PM
  4. modify post to add "next tool" variable after every tool change
    By allenp in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-22-2016, 08:56 PM
  5. Replies: 0
    Last Post: 05-22-2015, 09:00 AM
