603,790 active members*
2,911 visitors online*
Results 1 to 14 of 14
    Oct 2004
    76
    Choosing Stepper motors oz/in...
    I am building a DIY Router that uses acme rods for movement and the overall size is roughly 36 inches long, 24 inches wide with roughly 3-4 inches depth, I was going to purchase 166oz-in stepper motors but was recently told by a salesman that they would not have enough torque to get the wanted IPM. S he suggested I get the 400 oz-in motors the price difference is roughly $45.
    Is this a good assumption or will I be fine with the lower oz/in?
    Feb 2009
    28
    I'm certainly no expert so don't take this as gospel but if it were me I would go with the bigger motors. 166 sounds a little small and I'd rather be overpowered than underpowered. Forty five bucks isn't much difference and you'll be money ahead if it turned out the 166's couldn't handle the load. On the other hand you might do some tests to determine just what your torque requirements are. I haven't seen a lot of builds with 166's but that doesn't mean they won't work.
    Apr 2005
    256
    ahhh now now, we need to know what feed rate you're after, the type of acme rod ie size and number of starts, what are you going to be cutting?
    Might have seemed like a simple question, one I have asked myself before:wave:
    but you'll do well to get a simple answer, in saying that there seems to be loads of builds using 380 oz/in motor with great results so I would go with the 400 oz/in motor you mentioned.
    :cheers:
    I'll get it finished sometime after I start it.....
    Oct 2004
    76
    I'm only looking to cut hobby stuff right off the bat, i.e. - balsa, light 1/8 plywood and such. The acme rod I have is 1/2 x 10 not sure of the start.
    this has been an ongoing project for the last 5 years and I am finally getting around to purchasing the electronics from probotix.com
    Will I need the same size motors for all axis or can I use a smaller oz-in for the z axis(depth)?
    Apr 2005
    256
    well if its single start then the lower power motors would do, but as all steppers run out of puff with higher rpm you'll never get high feed rates even with the larger motors.
    But having said that you'll quickly tire of slow feedrates and look to upgrade to mutlistart rod at which point the higher power motors will come into play.
    The 400 oz/in motors will work with single and multistart rod easily, the 166 may struggle with multistart. If the cost for both is similar then go for the 400,well thats my opinion and am sure others will have theirs
    cheers
    Mar 2003
    35494
    You'd probably be better off with the 260 oz motors. They'd still be good enough for 2 start screws as well. I use 250 oz motors with 1/2-8 2 start and get pretty good performance with a Xylotex drive.
    I wouldn't get the 400 oz, unless you go with 5 start screws.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2003
    35494
    Quote Originally Posted by mrbaseball View Post
    Will I need the same size motors for all axis or can I use a smaller oz/in for the y axis(depth)?
    Z axis is up and down, and yes, it should have the same size motor. Most people think it wouldn't need as much power, but it can actually need even more power, as it has to fight gravity.
    Gerry
    Apr 2009
    5516
    Quote Originally Posted by robe_uk View Post
    cheers
    The finer the pitch on the screw, the smaller a stepper you can use. The problem of course, like most mentioned, is you'll lose some torque as you speed up. To note, a lot of mini mills use 166in oz and smaller steppers, but they have 10, even 20, tpi leadscrews, and the machines are small where rapids and high feedrates are not much concern.
    Generally the coarser the screw pitch, the more torque you'll need. You won't have the same "resolution" as a fine pitch screw, but you probably won't need it, especially cutting wood. As for wood cutting, which require high rpm spindles to cut cleanly, the feedrates are faster, to prevent twood burning and premature bit wear.
    Check out the geckodrive website; Marriss of geckodrive has some great articles on motor sizing, and steppers in general; and it may help you make a better decision.
    Jan 2008
    853
    Just to be pedantic, I believe that the units of torque should be oz in, not oz/in. The difference is important especially when doing conversions.
    Another consideration : The high torque motors (eg 400 oz in) have higher coil inductances, which means that you need a higher voltage power supply to get maximum performance. To get this higher performance your controller must also work at higher voltages. My Gecko G540 is limited to about 50 V, so that means the maximum inductances would be ~2 mH, which means it can push the under 200 oz in motors to their performance limits. I think the Gecko formula was Vmax( in volts) =32 x (Inductance in mH)^0.5, but check the Gecko site before making any decisions. There is little point in having strong motors with underpowered drivers.
    Cheers!
    I have 425 oz*in motors and wish I'd bought the 376/380/387 oz*in motors like those available from Keling. They have a better torque curve - they have higher torque at high speeds than the the larger motors. These work really well with the Gecko G540 controller. I think Gecko even sells a motor this size now.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Mar 2003
    35494
    I got a PM from the original poster saying that he's thinking of purchasing the Probotix Unipolar drives, which are similar to the HobbyCNC.
    With a Unipolar drive, the 400 oz motors are actually 300 oz motors with a much lower inductance, so they are a much better match for a Unipolar drive.
    With a bipolar drive, however, the 400 and 425 oz droves are not the best choice.
    Gerry
    Jan 2008
    853
    The Gecko motor is actually 280 oz in
    Oct 2004
    76
    Yes, Gerry has been very helpful as he cut my gantry sides and backing several years ago and I am just now getting around to actually finishing what I started!!
    I was originally on track to purchase everything from Hobbycnc, but not having the honed soldering skills I am very hesitant and would rather purchase a "plug and play" driver with or without breakout boards etc. At least that way if they don't work I KNOW that its not a result of poor soldering skills
    I am leaning heavily on the PBX -2 CNC Parallel Port breakout board and 3 Probestep Stepper Motor drivers, mainly because of price and aforementioned concerns.
    I did go ahead and purchase 3 of the 425oz-in bipolar rating, 305oz-unipolar rating stepper motors from Dave at hobbycnc. I don't know if it was the best decision, but I had to make one otherwise I would be comparing specs and such till the cows came home and/or I drove myself nuts!
    Its definately a lesson in learning and I am glad that we have such a forum to "pick" the brains of fellow CNC'ers that have already done this.
    I will ultimately like to use this machine to fabricate parts for a larger more advanced and more capable machine.
    Below is a feable attempt at using Google sketchup to see what the gantry would look like.
    BTW - I probably should start my own thread about my build just to keep track of it....
    Apr 2005
    256
    Quote Originally Posted by jsheerin View Post
    Thats an interesting comment, I had been looking at ebay motors 400+ oz in, cash flow has held me up as am saving up for a family holiday, hopefully i'll have a better understanding by the time i do come to buy motors :violin:
  1. Help sizing and choosing servo motors
    By Magnus B in forum Uncategorised MetalWorking Machines
    Last Post: 04-06-2010, 12:49 PM
  2. Choosing motors and the machines that fit them
    By Doggitter in forum Servo Motors / Drives
    Last Post: 02-17-2010, 03:50 AM
  3. choosing and understanding spindle motors
    By cyclotron in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2008, 02:14 AM
  4. Help with choosing steppers motors
    By Biggermens in forum Stepper Motors / Drives
    Last Post: 03-28-2005, 08:03 PM
  5. Help with choosing steppers motors
    Last Post: 10-22-2004, 04:23 AM
