603,967 active members*
1,838 visitors online*
Results 1 to 4 of 4
    Dec 2005
    59
    Chuck close in program
    Is it possible to use a chuck close M-code at the beginning of a program on a Fanuc 6TB control? The interlock is not letting me do this as it thinks it 'unsafe'.
    Jack of all, master of none
    Galveston, TX
    Mar 2004
    761
    Did you issue a "M05" spindle stop and "G04P2000" dwell time before the chuck close M-code?
    Wayne Hill
    May 2006
    265
    Try M31 (chuck bypass) before operating the cuck in PRG.
    (mabe this is the interlock you are talking about??)
    Dec 2005
    59
    There is a safety interlock for the cycle start. If the cluck is not closed the cycle start will not function(as well as other safety features). Even if I added something to the program it will not cyclestart if the cluck is open. I was hoping I would find a parameter to change. I did try the m31 in MDI and it does not complete the function, as though the NC is waiting for a input for the command to complete. I have not had time today to play with this further, but will get back on it in time.
    Galveston, TX
