603,848 active members*
2,494 visitors online*
    Jan 2007
    66
    Chuck mounting options
    I am planning to add another lathe to supplement my Unimat PC. I have been looking at a number of the small units - particularly the 8 X 14 - size is right and price is OK - but -
    All of these small Chinese lathes appear to use bolt-on chuck mounting. I find with my Unimat, that I am routinely switching among 2 3-jaw chucks, a 4-jaw and a collet holder, all of which are simple screw-on mountings. The idea of going through a fiddly bolt-on procedure each time is not appealing.
    Does anyone make a bolt-on adapter for these lathes that will, in turn, allow mounting a standard screw-back chuck?
    Pretorien
    May 2003
    325
    I've been watching the 7x lathes and accessories for several years now (and using one for a couple) and have never seen such a beast.
    I'll bet if you had the lathe it wouldn't take too much effort to make one that would be as accurate as the lathe allows.
    robotic regards,
    Tom
    It’s easier to teach a writer engineering than an engineer writing.
    - - Tom Thornton
  1. Help with mounting a new 4 jaw chuck
    By medfoch in forum Mini Lathe
    Last Post: 08-20-2007, 11:05 PM
  2. mounting chuck to rotary table?
    By dahui in forum Shopmaster/Shoptask
    Last Post: 05-20-2006, 04:56 AM
  3. Chuck Drill Chuck Alignment
    By TomV in forum Mini Lathe
    Last Post: 04-27-2006, 07:20 AM
  4. Mounting Your VFD.
    By Willyb in forum CNC Machine Related Electronics
    Last Post: 10-02-2005, 03:49 PM
  5. C42 mounting
    By DAB_Design in forum Servo Motors / Drives
    Last Post: 09-15-2004, 07:48 PM
