587,188 active members*
3,413 visitors online*
Thread: Chucking
    Dec 2015
    30
    Chucking
    Is there a feature in ESPRIT that you can define od or id chucking? I have an operator that is wanting to switch how he is holding a part which currently is 3 jaw od to a 3jaw id but I'm not sure if this is a machine specific thing to get the program to run or if I need to switch something within ESPRIT. Thank you for any guidance!
    Nov 2012
    19
    Re: Chucking
    In the machine setup you can choose the way you chuck. But you will probably have to change the setting on the machine to switch from OD to ID chucking.
  1. Using a Chucking Reamer
    By Bob La Londe in forum MetalWork Discussion
    Last Post: 01-29-2014, 03:43 PM
  2. SL-10 - Chucking
    By jpthorpe1041 in forum Haas Mills
    Last Post: 03-19-2012, 02:10 PM
  3. ID Chucking Brass with No Marks
    By jheal4 in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2011, 10:23 AM
  4. Chucking on Tapered Hex
    By Tazzer in forum MetalWork Discussion
    Last Post: 01-18-2009, 02:18 AM
  5. spline chucking
    By reachraghu in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-09-2007, 09:14 PM
