Register now for the 'CIMCO EDIT 2022 Integration in SolidCAM 2021' webinar -
https://register.gotowebinar.com/reg...96113206650128
Presented by Amod Onkar
DATE: November 11, 2021
TIME: 1:00 pm GMT / 8:00 am US Eastern
SolidCAM 2021 introduces the seamless integration of CIMCO Edit Professional 2022 version. CIMCO Edit is the editor-of-choice for professional CNC programmers who demand a reliable, full-featured editing, simulation and communication tool. Built for CNC programmers and machinists on the shop floor who need a fast and dedicated NC editing and programming tool. SolidCAM 2021 provides a single button transfer of Gcodes, Workpiece, Stock & Cutting tool information into CIMCO Edit Professional. In this webinar we will touch upon the following points:
Why do you need a GCODE Simulator like CIMCO
Difference between Standalone & Integrated CIMCO Edit Professional
Setting up and working with CIMCO
Machine Definition inside CIMCO
Miscellaneous Functions in CIMCO
Key takeaways from this webinar would include the following:
Understand the difference between SolidCAM toolpath Simulation & GCODE simulation.
Catch costly errors before actual machining.
Check syntax errors right on the PC and not on the controller
Switch between Heidenheim & ISO programs at the touch of a button
Mirror & Rotate programs without having to reprogram them again
Understand the use of CIMCO as a DNC program
Machine right the first time with confidence
