587,189 active members*
3,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Dart 500 Carousel Tool changer problems
Results 1 to 5 of 5
    May 2016
    9
    Trying to setup The Tool changer, Erratic behaviour, When we call for a tool change, it declamps before entering the carousel, dropping the tool on the bed, This happens when we are at tool 1 and call tool 1, if we are at tool 1 and call any other tool, it will not go to tool one, The carousel starts moving and the spindle enters at the called tool. We tried adjustiing the proxy for tool pot empty, But it gave a new alarm 1025 - Unidentified tool, It is behaving like random pot arm type,rather than carousel, Can anyone help me with this.We are just unable to get it working right, Cannot identify if it is a pull stud / drawbar problem, electrical problem or program issue.
    Dec 2006
    585
    Re: Cincinnati Dart 500 Carousel Tool changer problems
    Sounds like you have the wrong tool stud or the spring washers in the draw bar are broken. Can you try to explain the problem better.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Mar 2011
    464
    What control do you have? Cincinnati's control logic won't let what you describe happen (at least not on any machine I've seen). Is this a retrofit?
    May 2016
    9
    Quote Originally Posted by meckardt55 View Post
    Hi Meckaedt55,
    I dont have the correct pull stud, and I am unable to find one. So basically we are doing trial and error with various pull studs, I would be really greatful if I get help finding the proper pull stud. It is really driving me nuts. The drawbar is working fine, with other pull studs I am able to run the machine fine, Cannot use the tool changer.
    Thanks a ton for the reply, Finally I seem to be getting somewhere
    May 2016
    9
    Quote Originally Posted by maver1ck View Post
    Hi Maver1ck,
    Thanks for the reply, It is not a retrofit, It is a Dart 500 with GE Fanuc 21i-mb. I got all the manuals as well. We have been suspecting the pull stud. But any help is welcome.
  1. CNC ROUTER MACHINE RC1631S-ATC WITH CAROUSEL TOOL CHANGER
    By Baiansy in forum Roctech CNC Routers
    Last Post: 05-09-2015, 08:39 AM
  2. Carousel Problem on VMC1000 TNC426 Tool Changer Not At Pocket Alarm
    By iknownothing in forum Bridgeport / Hardinge Mills
    Last Post: 07-30-2013, 05:36 PM
  3. Tool carousel problems
    By jeffea in forum Mitsubishi controls
    Last Post: 03-06-2012, 12:27 AM
  4. Cincinnati DART - what do you think?
    By Alfonzo in forum Cincinnati CNC
    Last Post: 08-18-2009, 11:24 AM
  5. Troubles with a VMC Cincinnati Dart 500
    By Manuel meraz in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2008, 03:05 PM
